C3 ZR engine code ??? CKZ ???
Old Feb 11, 2009 | 09:00 PM
solid dobe's Avatar
solid dobe
St. Jude Donor '21
Default C3 ZR engine code ??? CKZ ???
This Corvette coupe is optioned as an standard LT-1, but the factory installed the CKZ engine destined for the legendary ZR-1! Corvette experts around the country are fascinated by this engine/option combination. The car is numbers matching and has all the correct LT-1 options, but the factory installed an engine with ZR-1 performance option code. Rare indeed!
I'm the first to admit I don't know a lot about C3 ZRs but does the above actually mean anything? My understanding was that all C3 ZR1's had the LT-1, what is this seller talking about? Is it just typical seller's fluff?
I have no intent towards the car, just trying to educate myself.
I'm sure some others have come across this as it is on the bay but I don't want to break the rules with a link so I just copied and pasted the applicable parts below.
1972 Corvette LT-1 Coupe, Numbers Matching, with ZR-1 engine pad stamping!
The Bryar Blue paint is in good condition for its age. The odometer is working and shows 85,448 original miles. The exterior trim is all original right down to the rims and center caps. The black interior has been restored and is in excellent condition. The frame, radiator support and suspension pieces are solid and rust free. The vacume system for the headlights and wiper arm door is all new and a new gas tank has been installed.
A complete mechanical restoration was performed by ex-Richard Petty and Richard Childress car builder Rick Mann. The engine was balanced and blueprinted and filled with a Callies crank, Eagle Rods and 10:1 Speed Pro pistons. The top end consist of a Comp Cams hydraulic flat tappet cam with Brodix aluminum heads and Aluminum Roller Rockers. The original factory high performance aluminum intake is topped with a Holley 750 CFM carburetor. An MSD tach drive distributor and ignition box have been installed as upgrades for the ignition system.
The numbers matching M-21 close ratio transmission and posi-traction rear end have been rebuilt and all suspension bushings have been replaced. A complete book of restoration details and reciepts are available.
Old Feb 11, 2009 | 09:19 PM
dmayhew's Avatar
dmayhew
My understanding of the ZR-1 cars is that they were a LT-1 with several heavy duty extras added. All of the added stuff made the car more durable and maybe handle better on a road course. But as for power , it is just an LT-1.
I have seen the add on e-bay you are talking about.
To me this seller really has nothing to bost about. If this is a true factory block stamped for a ZR-1 that made it into a LT-1 then I see no WOW here. He has a screwed up stamp. But the stamping looks odd also.
Actually this would make me pass on the car.
just my .02 worth.
David
Old Feb 11, 2009 | 09:42 PM
hwcoop's Avatar
hwcoop
The documentation I have shows the ZR1s came with the LT1 motor, Cars were radio delete, no AC, No Power windows, had the F41 suspension, rear end gears up to 4.56,(YE3)Cars shipped bare wheels with no trim rings or center caps, J50/J56 HD Brakes. Cam was solid lifter, 0.452 intake, 0.455 Exh, 800cfm Holly pn R-4489-A(70 ZR1) 6,500rpm Redline tach
70-71 had no fan shroud and 72 had metal shroud
72 ZR1 option was $1010.
Old Feb 11, 2009 | 09:58 PM
66L36Coupe's Avatar
66L36Coupe
The C3 ZR1's used the "base" LT1 engine. That is to say, it was virtually the same as the standard LT1 in regard to HP, torque, etc. But here's where it differed:
All '70-'72 ZR1 coded LT1 engines required:
  1. -HD hi-torque starter from the L88 parts bin (Delco 351)
  2. -L88-style lightweight flywheel (smaller dia.,156 tooth, PN 3856579)
  3. -No radio shielding
  4. -403 bell housing
  5. -TI was required on ZR1's in '72, where on standard LT1's it wasn't
Is finding one of these suffixed engines significant? Yes - if it's in a ZR1 with all the other HD bits. Otherwise, I would consider it only "interesting" - but only if it can be proven it was installed on the line. It would be fun to inspect the car to see if there were any other ZR1 indicators - as well as investigating if any "real" ZR1's bracketed the car on the production line, as they often did.
Old Feb 11, 2009 | 10:24 PM
wfo76's Avatar
wfo76
The ZR1 package also included the M22 tranny and since he says this car still has it's
"numbers matching M21" then that should eliminate this car as being a real ZR1. I guess
it is possible that Flint incorrectly stamped the block but I'm thinking a screwed up restamp.
Any pics of this car or a link to the ad?
Thought it was 70-71 with a shroud and only the 72 without.
Originally Posted by 66L36Coupe
[*]-TI was required on ZR1's in '72, where on standard LT1's it wasn't
TI on a 72? Think it was gone after 71 even on the ZR1.
Old Feb 11, 2009 | 10:37 PM
hwcoop's Avatar
hwcoop
I got the information from an article in "Vette" magazine January 1990on the 70-72 ZR1, ZR2 Corvettes
p36 "Also a metal fan shroud was fitted to 72 ZR1. The 1970 and'71 examples did not have one."
The article also mentions they used the Aluminum Cross flow that was used in the 65 396/425hp applications and was used during the L88 era.
Old Feb 11, 2009 | 10:43 PM
solid dobe's Avatar
solid dobe
St. Jude Donor '21
I'm afraid of the mods. I found it by searching the bay for ZR* but based on the posts here the car is not too much of a big deal
Old Feb 11, 2009 | 10:45 PM
solid dobe's Avatar
solid dobe
St. Jude Donor '21
This one has some type of shroud.
Old Feb 12, 2009 | 03:02 PM
Solid LT1's Avatar
Solid LT1
ANY LT-1 with a hydraulic cam is NOT! a LT-1 in my book. TOTALLY DESTROYS the performance/response/exhaust note of the motor, you may as well have a L-46 Vette at that point.
Old Feb 12, 2009 | 09:46 PM
hwcoop's Avatar
hwcoop
Thats what you have for the 73 L82
To C3 ZR engine code ??? CKZ ???
