1981 HP Question
Old Feb 13, 2009 | 04:17 PM
spedaleden's Avatar
spedaleden
Default 1981 HP Question
The L81 motor was 190 HP at 4100 RPM. Is this rated at the crank or rear wheels. If this is the crank then the rear wheel HP had to be around 120 HP.
Am I correct or am I on something?
I just dynoed my car Last September and its now 290 RWHP. Was it that much of a dog?
Old Feb 13, 2009 | 04:41 PM
bb62's Avatar
bb62
The rated HP at the crank was (is for stock versions) indeed 190HP. You would have to put a stock car on the dyno to get the RWHP for a stock configuration. I would suspect that it would be higher than 120HP.
Old Feb 13, 2009 | 06:39 PM
spedaleden's Avatar
spedaleden
You would think with such little HP that motor should of gotten great gas mileage like 20 to 25MPG.
Old Feb 13, 2009 | 07:06 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I don't think it was at the crank. I think it was 190 HP at the rear wheels (net). The change to net HP occured in the early 70s (I think). That and the change to unleaded fuel and emission controls were the reasons for the steady decline in HP.
Old Feb 13, 2009 | 07:09 PM
pbcanney's Avatar
pbcanney
Old Feb 13, 2009 | 07:12 PM
Gordonm's Avatar
Gordonm
Net HP is not at the rear wheels. It is with all the acc. hooked up and run like it is in the car with manifolds. The old way was just the crank HP without all the acc. Rear wheel HP was never advertised or never really used until the newer cars came around.
So yes the 190 HP Vette was a real dog as far as performance. I actually drove one in about 82 and the V6 Citation I had then was actually faster.
Old Feb 13, 2009 | 08:19 PM
spedaleden's Avatar
spedaleden
Thanks Gordonm.
I bet my sons Cavalier is faster with half the amount of cylinders and weight. That L81 just sucked fuel and didn't breath at all.
Old Feb 13, 2009 | 08:26 PM
bb62's Avatar
bb62
You're still working with non-overdrive transmissions (both manual and automatic) that will be revving significantly into your torque curve at highway speeds.
I can not believe that people are out there who believe that any HP rating would be at the rear wheels. There are simply too many variables for the OEM to confirm. An engine system in a dyno room is much easier to control with respect to everything from fuel to ambient temperature. All HP ratings (net or gross) are engine only. The gross ratings from pre-72 included exhaust headers and no accessories. It also does not include the effect of the package environment, like access to airflow, engine heat from the radiator, cooling strategy, etc. Net HP takes all that into consideration.
RWHP is ideal for individual cars though and can give one an indication of how fast and efficient that one car can be.
Old Feb 14, 2009 | 12:13 AM
7T1vette's Avatar
7T1vette
You should also note that the rated HP was specified at 4100 rpm. It's not that the engine's max HP occurred at 4100 rpm...it's just that the engine generated that much HP at that point on the curve. If you revved it higher, it would make more power. But, rated HP was a 'killer' for insurance rates, so GM de-rated engine power so their customers wouldn't get "soaked" by the insurance industry.
Check the engine power specs on Corvettes from 1972 through 1991. Specified power points are as low as 4000 rpm...all in an effort to "beat the system". Even though those engines weren't as powerful as in earlier years, they would make more power than was spec'd.
Old Feb 14, 2009 | 02:30 AM
guitarcrazy02's Avatar
guitarcrazy02
This is a very good point. I got my 81 to run a 15.2 (I know, not impressive at all, but good for what it was) with only dual exhaust and original manifolds. No headers or anything. Everything else was bone stock.
Old Feb 14, 2009 | 03:08 AM
71coupe454's Avatar
71coupe454
does anybody know how desk top dyno results compare to factory ratings when you input stock specs? just curious, wondering if you can say factory says it was xxx but it realy was xxx ?
To 1981 HP Question
