Update photos on winter project
I was pleased that the opening numbers were both off by only 1/2 degree
The closings numbers were dead on.
I had called Crane to ask a question and a man in their tech department alarmed me by saying that the cam I had installed was way to radical for my motor.
I explained that is was the original replacement for the 71 LT-1 and he still said , to hold on tight when this thing reaches 3000 RPM
He stated the duration numbers were the main thing
The cam has 459 lift and 242 duration on intake
and 485 lift and 254 duration on exhaust.
Do these numbers realy sound so extrem?
I installed brass freeze plugs , I think the contrast in colors stand out nicely.
Will post more updates as they occur.
I now nned to get it into the car so I can start putting A Arms ans steering back on.
David
I thought you were making progress because I hadn't seen you on the Forum this week.
As usual your work looks TERRIFIC.
What did you decide to use on the exhaust manifolds?
Regards,
Alan
Yes , I have made some good progress lately. My new role at work has me traveling so much that I am getting concerned that I may not make my new mid April target date now.
As for the manifolds. After getting a 300.00 estimate to coat them, I decided I was jut not going to spend that money.
I had them sandblasted , and I used a material called HOT STUFF
It is about 10.00 or 12.00 for a small container.
It is a mix of stainless steel / ceramic and you brush it on in a thin layer
Let dry for 2 hours and if you can not start the motor to cure , you then place in a over for 1 hour.
I had used it last year and it holds up quite well for the expense.
I am out of town the next 2 week ends.
three weeks out my local buddy will help me get the motor back in the car so I can start putting the suspension back on.
I need to get the car rolled outside so I can break in the cam.
Will send more updates when they occur.
David
