rust on rally wheels?
Old Feb 14, 2009 | 09:14 PM
fhickey's Avatar
fhickey
Default rust on rally wheels?
Scrap 'em or is there an economical fix? 1974 model.
Old Feb 14, 2009 | 09:26 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Sandblast if you want them near perfect, if not wire brush them using a hand drill and wire wheel.
Old Feb 14, 2009 | 09:42 PM
bobl.2's Avatar
bobl.2
Default Rusty rallys
Yes a little elbow grease a good cleaning and good prep should net you some fine results
Old Feb 14, 2009 | 10:34 PM
Chris Farrer's Avatar
Chris Farrer
The hardest part is to get right into the seam where the rim is joined. I sealed it to give a smooth finish and prevent rust from starting again.
Old Feb 15, 2009 | 01:04 AM
71coupe454's Avatar
71coupe454
I got mine all sandblasted at a cemetary monument company, of all places, for $60.00 and had a friend of mine at a body shop primer/paint them for another $60.00. They look too good now to hammer my old beat up trim rings on now. So I'm replacing them now to.
To rust on rally wheels?
