I'm going to be removing the A.I.R (OK you NCRS and correct people, move along, nothing to see here...).When I disconnect from the exhaust manifold do I put bolts where the tubes were? If so how long?
I just removed the A.I.R. from my 73 350. I used 1/4-18 MPT socket plugs. The taper on these plugs do a good job of sealing and the plugs do not stick out far at all.
The threads in the manifold are straight threads 18 tpi. I did not re-tap, the NPT "face-plugs" will screw right in and seal real well. Face-plug is a common name for a plug that has a hex socket as opposed to a plug that has a square drive head on it. I actually bought a set of plugs from cc and all they were, were 1/4-18 Npt square drive plugs. But they stuck out too far and looked terrible. live and learn.............. steve
