rubber bumpers
Old Feb 15, 2009 | 09:15 PM
babylonvette's Avatar
babylonvette
Default rubber bumpers
i bolted the front and rear rubber bumpers on a 77 this weekend both used maybe 78/79 they are so distorted will they come back to shape with heat or just being bolted on,there is small spacing most of the way arround or will they have to be reworked by a body shop
Old Feb 15, 2009 | 09:40 PM
dannyman's Avatar
dannyman
Pretty much going to stay the way they are, when bolted in place. Any distortion beyond this point could be referred to as sagging. The space or gaps you have now certainly will not close up on themselves.
Old Feb 15, 2009 | 10:15 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
A friend of mine removed his front bumper to refinish it. Gave up trying to reinstall it.
He said it was as if it shrunk
Old Feb 17, 2009 | 09:42 PM
babylonvette
thanks for the replies ,i haven;t looked at it since fri ,i will see if it settled or came back to shape or it will have to be worked over, i;ll let you know
Old Feb 17, 2009 | 11:23 PM
onaqwst's Avatar
onaqwst
i bought new fiberglass bumpers and never looked back....
Old Feb 18, 2009 | 01:38 AM
gbvette62's Avatar
gbvette62
If they're wavy now, they're going to stay wavy. Not heat or cold, sun, or anything else, will take the waves out. The urethane loses it's shape with time. The 76-79 bumpers seem to distort the most.
If you have gaps where the bumpers bolt to the body, they'll remain there, too. How did you bolt the bumpers up? Did you use the original style retaining strips, or the "T" bolts available on the aftermarket. The retaining strips do the best job of pulling the bumpers up tight against the body. The "T" bolts work fine with the aftermarket fiberglass bumpers, but don't apply even enough pressure when used with urethane bumpers. When used with urethane bumpers, the uneven pressure applied by the "T" bolts cause gaps along the seems, in between the "T"'s. The only way to assure yourself of truely smooth bumper covers is to replace them with fiberglass, or the flexible fiberglass, ones.
To rubber bumpers
