Big block starter question
Old Feb 17, 2009 | 11:21 PM
$tingray's Avatar
$tingray
Default Big block starter question
I have a 1970 big block starter # 1108400, dated late 69, that has a type 5 iron nose on it. It has 2 mounting holes that bolt it to the block. My rebuilder says it is suspose to have 3 mounting holes in the nose and is going to change it out. My question is, which nose should I have to be NCRS correct? Thanks
Old Feb 18, 2009 | 10:25 AM
hurry88's Avatar
hurry88
Your starter is correct, cast nose, two bolts up from the bottom and one small support bracket in the rear...plus shielding and you are good.
