Rearview mirror mount
Old Feb 18, 2009 | 05:27 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Default Rearview mirror mount
When I was changing my rearview mirror, the mount fell off.
The only thing Autozone had was a 'peel n stick' mount.
It lasted two days and then fell off.
I then used rearview mirror glue. it lasted about 10 minutes.
I'm following the directions on the packages, but I've never had this happen before.
Old Feb 18, 2009 | 05:37 PM
7T1vette's Avatar
7T1vette
You must get both surfaces very clean and very smooth. Take the mirror off of the mount and use the rearview mirror glue (SuperGlue, really) to attach the mount. Put some duct tape over it to hold it in place overnight so it will fully cure. It should be warm when you do it or it may not stick or cure properly. Good luck.
Old Feb 18, 2009 | 05:53 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Went to a auto glass shop, charged me $10.00 to put it on, never had an issue.
Old Feb 18, 2009 | 08:16 PM
nutsy's Avatar
nutsy
IVE BEEN USING super glue since my 1st car. it works great. SCRAPE the old glue off with a razor blade 1st.
Old Feb 19, 2009 | 03:02 AM
RunningMan373's Avatar
RunningMan373
your problem is simple, the OEM windshields appear to be coated on the inside with a thin plastic, regular mirror glue won't stick. Get some fine sandpaper, 220 to 400 grit. Then, trace out the outline of the metal pad onto the windshield, then lightly buff the Complete (no smooth corners) outline. Then clean the area with some alcohol, and glue it back on. mine been on for year and a half now
To Rearview mirror mount
