HELP subwoofer won't work at all!
correct-- i dont know of any headunit in itself that will power a sub. that sub output from your HU will go to an amp and then to a sub. If this is the case, then you may be close with having to turn on the sub output. It should be in the crossover section of the settings on your HU. But.... you have 4 outputs. that would lead me to believe you only have front and rear right/left outputs. these would be stereo only no sub output. So if you are crossing over those outputs at lets say 500hz and up via the HU then thats the signal that is going to the sub also (if connected) and because most subwoofers will play within 150hz and down you wont hear anything. what model is it?
clif notes from what i have read
1. you have dedicated front and rear stereo outputs.
2. no sub output RCA
3. your HU crossover is too high
idea--- what i would do is forget about the crossover in the HU itself. these are good for daily driver 4 speaker systems really. Find an amp that you like prefer one with a sub out would be good. Run your cables to that amp and use the crossovers off of that. to get what you are looking for.
you can also obtain the correct frequency using an electronic crosover inline of a pair of RCAs for the sub (usually rear outputs produces better results) puting the crossover first, then the amp and then to the sub. this will leave you a pair of RCAS for stereo (speakers will loose fade function with this idea)
correct solution--- get a 4 channel amp with a sub output and your all done! if it has full pass crossovers then great if not then you can utilize the ones in the HU. Whhheewwwww! thats alot of writing and reading only to find you have to flip a setting in the HU
Rick B.
What Pioneer model is the headunit?
good thinking with the remote turn on. (blue wire)
1. Ensure that the gain on the amp is not turned all the way down.
2. On some HU's you can turn on/off the sub preout, additionally, some HU's have a sub volume, so if your HU has these capabilities, its menus that's worth a check.
Good Luck
This is a good place to start, after reading more throuhly, since you have 4 RCA preouts, most likely they are just front and rear, in most cases you will only have HU sub control if you have a sub preout and that does not sound like the case.
