Bilstein vs QA1 shocks
Old Feb 21, 2009 | 07:14 PM
turbojet's Avatar
turbojet
Default Bilstein vs QA1 shocks
Thinking about shocks for my 71 small block, stock rear leaf and stock
front end. What are some of the benefits of each one.
Old Feb 21, 2009 | 08:07 PM
Doinit Once's Avatar
Doinit Once
I put Bilstein's on my '75 last year for $300 from Mid America. To be perfectly honest they could be Gabriels from the local parts store. No doubt they will last longer than a pair of Monroes or Gabriels, but the ride is really not much different. I clock about 1500 miles on this car a year and I'm sure a set of $125 stock shocks would have worked out just fine for the next 10 years.
Old Feb 22, 2009 | 08:57 AM
turbojet's Avatar
turbojet
Has anyone used the edelbrock IAS or KONI shocks what are you guys using out there on your vettes.
Old Feb 22, 2009 | 09:36 AM
SmokinBBC's Avatar
SmokinBBC
I used the IAS shocks with 550 front and 360 composite rear on my beafed up BB. Excellent shocks. Before those I had KONI shocks...excellent shocks. Now I have the Billstein sport...excellent shocks
The Konis are adjustable ...pain though since you need to adjust them off the car. They came on the car when I bought it...they were quite old and beat up But, they performed well.
IAS was perfect balance between sport handling and ride comfort. They handled the rough roads really well and also delivered nice performance on the twisties.
The Bills. sports are "tight" and you feel much more of the road...but they are better on the twisties. They are fine for the weekend warrior type driving that I do now.....you know, the 10mpg type driving.
I am going to do a couple of longer trips. When I do those, the IAS are going back on.
IMO, If you like to play with the vette and want to try different things, then go Koni. If you don't want to play around with it, but want all around performance, go IAS. If you like the stiff feel...then Bills.
Again, just my humble opinion on those 3 shock brands.
Old Feb 22, 2009 | 09:58 AM
turbojet's Avatar
turbojet
Thanks thats a good breakdown now if someone wold chime in on the QA1 shocks.
Old Feb 22, 2009 | 12:38 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I'll second that on the Edelbrock IAS shocks . I like them for a non-adjustable shock. They are excellent street shocks and decent track shocks. However, I only do HPDE's and I am still learning (i.e. novice ). If your serious into tracking the car, an adjustable shock would probably be better.
Oh by the way Bilstein has 3 versions: HD, sport, and extreme. I tried the extremes but they were too stiff for the street. I have no experience with the HD or sports.
Old Feb 22, 2009 | 12:51 PM
C3 Stroker's Avatar
C3 Stroker
I have QA-1 adjustables on the rear of my '69. I got them because of performance (drag strip).....you can adjust them independently to eliminate sway on take off and reduce rear end squat. If you want a softer street ride, just a few clicks and you have that too. I'm very satisfied with them.
Old Feb 22, 2009 | 01:31 PM
spf72's Avatar
spf72
I put the QA1 coil over adjustable on the front and Bilstiens in the rear. I still havn't put the body back on so I can't speak of the ride. I had a discussion with both Van Steel and VDP and I am following their advice - we will see.
Old Feb 22, 2009 | 01:40 PM
turbojet's Avatar
turbojet
Any pics and is there any customizing involved.
Old Feb 22, 2009 | 01:53 PM
OURSHARK's Avatar
OURSHARK
I put QA1 adjustable's all around on my car, I have them set for a soft ride. If I want to stiffen the ride, it just takes a few clicks. I like them very much.
Old Feb 22, 2009 | 02:08 PM
spf72's Avatar
spf72
Not sure if you meant me but here are a few pics just in case - work in progress.
Old Feb 22, 2009 | 02:23 PM
column5's Avatar
column5
This is a timely thread: I installed Bilstien Sports on all four corners yesterday. I replaced a set a of Gabriels that were a year old. The objective was to reduce body roll and eliminate my Pypes exhaust dragging when hitting certain dips in the road (the Pypes system hangs a bit lower than the stock exhaust).
It was raining yesterday so I drove it with the new shocks for the first time this morning. There was definately a big difference. From a purely objective standpoint, the exhaust no longer scrape even at places in the road where they always scraped before. There is a also a definite decrease in body roll.
Subjectively, the car rides a bit firmer than before, but it is in no way jarring or rough. That is probably why (no offense meant here) someone who doesn't drive their car often, or hard, would not notice a big difference.
For $300 + shipping from Summit I am very happy, as a serious problem was resolved and the car handles much better when being driven hard.
Old Feb 22, 2009 | 02:35 PM
turbojet's Avatar
turbojet
Thanks those pics are great is it a straight forward swap of the front spring for the QA1 struts, and why did you not go with the QA1's in the rear. Thanks again for the response.
Old Feb 22, 2009 | 03:08 PM
spf72's Avatar
spf72
I spoke with several people and explained my use - never will be raced or course driven. Really just street driven and an occasional twisty road. They said with the fiberglass rear spring that the Bilsteins would be my best choice. And then it was price - the QA1 were around $160 each and the Billsteins were around $160 a pair.
Old Feb 22, 2009 | 03:14 PM
spf72's Avatar
spf72
I forgot - yes the swap is quite straight forward with no fab work at all. A very easy change with the hardest part getting the old springs out.
I did pull one of my more stupid maneuvers on the change - I was installing the shocks up through the tower and they were quite short so I started to rig up all sorts of chains and devices to pull the spring up when I happened to grab the shock rod and realized it had around 4 inches of travel left and pulled right into place. I laughed at myself for several days over that one - a good humbling experience. Thank God I didn’t hurt myself!
Old Feb 22, 2009 | 03:52 PM
682XLR8's Avatar
682XLR8
If you decide on the Bilsteins, VBP is still having their 20% off sale through the end of the month. I bought the Sports & installed them last weekend
Old Feb 22, 2009 | 05:12 PM
turbojet's Avatar
turbojet
[QUOTE=column5;1569045176]This is a timely thread: I installed Bilstien Sports on all four corners yesterday. I replaced a set a of Gabriels that were a year old. The objective was to reduce body roll and eliminate my Pypes exhaust dragging when hitting certain dips in the road (the Pypes system hangs a bit lower than the stock exhaust).
These are some of the same reasons I need to change my shocks KYB's
sometimes my hooker sidepipes scrape the ground. Not to put down the KYB's they are old.
To Bilstein vs QA1 shocks
Old Feb 23, 2009 | 02:41 PM
WillEE's Avatar
WillEE
The QA1s are pricey but they look damm nice bolted in and the adustability is key with these - you can't be dissapointed with what you get (too soft/too firm) cause it's up to you to tune them in. I like mine. No experience with the Bilsteins - I've heard people rave about them and others complain. Sometimes I wonder if people rave about their new shocks (whatever the brand) cause they are comparing a 25 year old worn out shock to the new one they just put on which suddenly feels so much better.
Old Feb 23, 2009 | 06:13 PM
turbojet's Avatar
turbojet
What would be the difference between the QA1 double and single other than the price.
Old Feb 23, 2009 | 07:26 PM
C3 Stroker's Avatar
C3 Stroker
The double ones can adjust upward and downward movement independently. Singles adjust both simultaneously, whether stiff or soft. If you want more rebound, for example, you can have it with the doubles.
