wiper door
Old Feb 22, 2009 | 05:51 PM
ndmick's Avatar
ndmick
Default wiper door
When I start my 71 coup the wiper door opens(lifts up).The only way to close it is manually.Is it the wiper door actuator vacum relay?
Old Feb 22, 2009 | 06:21 PM
ndmick's Avatar
ndmick
any ideas?
Old Feb 22, 2009 | 06:32 PM
71coupe454's Avatar
71coupe454
I dont have much of a clue on the wipers or the lights, but there are some good threads in here for diagnosing vacuum problems. You need to see why you have vacuum to the diapham when you shouldnt. I think the line on the front closes the door and the line on the back side opens the door.
Old Feb 22, 2009 | 06:37 PM
mrvette's Avatar
mrvette
the vacuum relay control line, the small one feeding the diaphram, that is set so that the small line has vac on it to pull the door DOWN....closed....so if there is a failure in that/those controls you have the door OPEN, so the wipers work....
there is a vacuum switch on the pass side wiper....there is a electrical vac relay that kills vac to the line when activaed by the wiper switch....behind the speedo down lo.....and of course the main feed vac line to the entire system....
so just remember the key to the signal system is suck Closed....
same with the headlights....no vac to the realy diaphram..it's OPEN for everything....
Old Feb 22, 2009 | 08:42 PM
chrome bumper's Avatar
chrome bumper
Che3ck to see if the override switch under the steering column is is the override position.
Old Feb 22, 2009 | 09:21 PM
Young69Owner's Avatar
Young69Owner
You have a leak. Listen for hissing right after you turn your engine off and even while it is running. Having a friend stand over your open hood will help. If you discover the leak, you will be all set. Nothing vacuum-related on mine used to work, now it all does.
Old Mar 7, 2009 | 07:27 PM
ndmick's Avatar
ndmick
Finally spent some time on this issue ,it was thewiper solenoid door actuator.Just like mrvette said THANKS FOT ALL THE IN PUT.
Old Mar 8, 2009 | 09:28 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
To wiper door
