clean up
Old Feb 25, 2009 | 06:34 AM
2TS-73's Avatar
2TS-73
Default clean up
i am just now getting around to the clean up and repaint of the underside, my question is what does everone do with the fiberglass on the underside , do you paint it like the rest after it is clean or leave it alone?
Old Feb 25, 2009 | 11:14 AM
rosslato's Avatar
rosslato
i put a coat of por-15 on the whole shell, provides a nice hard cover and easy to wipe clean.
Old Feb 25, 2009 | 11:48 AM
spedaleden's Avatar
spedaleden
I painted mine
Old Feb 25, 2009 | 12:51 PM
eastltd's Avatar
eastltd
If you have the underpanels cleaned up it is worth the time and effort to paint them.
Make sure you add a little undercoating just to the top to the wheelwells to prevent rocks from cracking the topside paint.
Good Luck
Old Feb 25, 2009 | 05:24 PM
Alan 71's Avatar
Alan 71
Hi 2TS,
While the fender wells had some undercoating and some semi-flat blackout, the underbody was left natural. So it depends what look your after as to what you do because the underbody could be semi-flat black too.
Regards,
Alan
Old Oct 5, 2019 | 05:24 PM
newblue1991's Avatar
newblue1991
Uh1... What is Por -15? Thanks
Old Oct 5, 2019 | 06:36 PM
sullyman56's Avatar
sullyman56
POR-15 is a rust preventative coating. By the way, you’re responding to a ten year old thread.
To clean up
