update with some questions..
so anyways....... heres the problem. it wont start... fuel pump is bad (unless im supposed to prime it someway that i am unaware of), but poured gas down carb. no firing.. or starting. definitely have spark. definitely have batt power, even connected jumpers just because. the engine is older, and probably hasnt been run in quite a while. about the only thing wired is the ignition.
holley carb (brand new, not adjusted)
street fire hei distr. the tach wire is currently ground, because this is a '54 vette, with original mechanical tach.. (brand new, not adjusted)
block # 14093638
distrib stabbed @ TDC on combustion cycle, possible tooth or two off, though i still figured if this was the case, it would fire.
one thing i did notice, out of the valve cover DS, the hole was not plugged and i saw gasses? being expelled... and on the PS the valve cover was moving like a bottle when you press on the sides, like it was sucking in and then returning to normal.
any ideas?
edits: picture shows coil with point dist.. this HAS been replaced, as i couldnt get it to spark due to worm dist, and no resistor is run, just straight 14g from ign switch. block off for fuel pump is also shown, manual fuel pump reinstalled due to more room than anticipated. i have also disconnected the belt, so that the alt and waterpump are not slowing down cranking, the alt isnt wired anyways.
Put a timing light on the #1 plug to confirm that you are getting a spark.
It should try to fire with spark, fuel and air.
Good luck.
I have a strange suspicion that could be your problem.
