need help with casting #'s
Old Mar 4, 2009 | 11:42 AM
madmax396's Avatar
madmax396
Default need help with casting #'s
Looking at a 71 vette that has been sitting for a while. I know the LS5 is not original but was wondering if you could help me with what these parts are and where they came from.
Block 454: casting date J 18 73
casting # 8999289
pad stamp# T1107CWU 140168468
cater carb: 7044223
L3 FH
intake manifold: casting # 336789
casting date J 22 73
I havent pulled the valve cover yet for the head castings. I was told it was an all orginal 71 454 with the exception of the block being a 73 corvette block. From what I can tell none of it is from 71. Casting dates on the block and int. manfold being oct 73. Also I dont think the CWU on the block is a corvette block.
Can anyone tell me what the block, intake man. and carb came from? Also what carb is this 750, CFM?
Thanks everyone
Old Mar 4, 2009 | 11:48 AM
madmax396's Avatar
madmax396
One other thing. Is a 71' vette LS5 supposed to have an aluminum intake manifold? This one is steel, painted silver to look like aluminum.
Old Mar 4, 2009 | 01:08 PM
Mike Ward's Avatar
Mike Ward
CWU is:1974 454/235 TH Police
336789 is a cast iron manifold used on lots of early 70s BBC, not just Corvette.
7044223 is a Qjet also from lots of 74 BBC.
Old Mar 4, 2009 | 01:21 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by madmax396
...From what I can tell none of it is from 71....
I'd say you were correct.
Old Mar 4, 2009 | 02:06 PM
madmax396's Avatar
madmax396
Any way to tell what CFM the carb is?
Thanks for the replies
Old Mar 5, 2009 | 12:00 AM
Mike Ward's Avatar
Mike Ward
Most probably a 750CFM.
Old Mar 5, 2009 | 12:05 AM
madmax396's Avatar
madmax396
Pulled the valve covers tonight. Casting 336781 with date of K 2 73. Looks like its all out of a 74 model year car.
Old Mar 5, 2009 | 06:32 PM
joewill's Avatar
joewill
yes it is a oct 73, model year 74 454 block.. you could say its a corvette block, but the guts are not, corvettes used this same block, but the block did not come out of a corvette, if that is the question?
To need help with casting #'s
