Hard time holding down the softtop
Old Mar 8, 2009 | 11:44 AM
c3_dk's Avatar
c3_dk
Default Hard time holding down the softtop
Hi,
I am having a hard time holding down the soft top in the rear. (1969)
What can I do?
Regards,
John
Old Mar 8, 2009 | 11:58 AM
Melwill68's Avatar
Melwill68
The hard top or the soft top? If it's the hard top, do the soft top latches engage ok?
Old Mar 8, 2009 | 12:14 PM
c3_dk's Avatar
c3_dk
SORRY..... soft top
Old Mar 8, 2009 | 12:16 PM
Don B's Avatar
Don B
Had same poob buy new pins they get rounded and wont stay Paragon is where I got mine.
Old Mar 8, 2009 | 01:38 PM
Duke94's Avatar
Duke94
Also check for wear on the latch portion. As well as for a broken spring on the latch.
Old Mar 8, 2009 | 01:54 PM
seventysixvette's Avatar
seventysixvette
with duke.
You also might check the latches to make sure they aren't adjusted so far that they're only half closing. In the pic I've circled the latch with green. At the other end of the cable is adjustment nuts circled with red.
My latch cables were adjusted so badly (tight) the latches didn't stand a chance of grabbing hold of the soft top pins.
John
Old Mar 8, 2009 | 02:26 PM
c3_dk's Avatar
c3_dk
Thanks all......
BR,
John
Old Mar 8, 2009 | 02:28 PM
rcread's Avatar
rcread
I just drive around with the top down all the time. Problem solved.
Old Mar 8, 2009 | 03:40 PM
c3_dk's Avatar
c3_dk
He-he come to Denmark, Europe and I think that you also would put the top up sometimes
Old Mar 9, 2009 | 12:39 AM
rcread's Avatar
rcread
Originally Posted by c3_dk
He-he come to Denmark, Europe and I think that you also would put down the top sometimes
I've actually been to Denmark, lived in France. You make a valid point.
Old Mar 9, 2009 | 12:47 AM
PRNDL's Avatar
PRNDL
I actually replaced the pins with big old bolts... big new bolts really. I have to pull the latch to insert the bolts because unlike pins you cannot push them through, but they hold the top down better than the skinny pins.
Old Mar 9, 2009 | 12:17 PM
c3_dk's Avatar
c3_dk
Sorry for my bad bad grammar, but you understood me, that is the important thing
To Hard time holding down the softtop
