Are Power Sterring Pumps Date Coded?
Old Mar 9, 2009 | 11:23 PM
Rick Church's Avatar
Rick Church
Acct suspended by request 8 Nov 2012
Default Are Power Sterring Pumps Date Coded?
I have a 71 matching numbers car. When pulling in and out of parking spaces, the power steering pump is howling. When the car is stopped and I try turning the wheels, the pump moans and groans. The Autozone, Advanced Auto, and NAPA pumps all meet OEM specs but I'm concerned about non-matching number parts. Are the pumps date coded? Who sells a quuality replacement pump? Can pumps be rebuilt?
Thanks from Rick in Tennessee
Old Mar 10, 2009 | 12:07 AM
Frogday's Avatar
Frogday
This site has a lot of pictures of a power steering pump rebuild:
http://www.corvette-restoration.com/...mp_rebuild.htm
Old Mar 10, 2009 | 07:05 AM
Jim Shea's Avatar
Jim Shea
The date code is stamped on the side of the reservoir as shown.
Most automotive stores sell a pump housing. You swap your reservoir onto the housing. So any date coding transfers to your new pump.
You also swap your spring, flow control valve, and discharge fitting. This insures that flow and pressure relief will be the same as your original.
Jim
Old Mar 10, 2009 | 07:15 PM
Rick Church
Thanks Jim!
To Are Power Sterring Pumps Date Coded?
