Were getting ready to pull the motor for a good stroking. While shes down were upgrading to Power Steering. I thought about going the jeep route but decided against that much fabrication. So looking at conversion kits I find the following:
So other than Ecklers gives you a quart of fluid, what the difference in these kit's. Is it possible the Ecklers kit is of sufficient higher quality to justify the price difference? I am concerned about some repro parts and am always willing to pay a little more for higher quality.....but something nagging says some or most of these parts originate at the same factory.
As long as you are in the US lower 48.....I will put the complete kit on your door step for 760.00.This is everything,but the belt.These are te same kits.
My supplier supplies most these kits to all these other places,so this is how i can make them cheaper like this.
Almost ALL the suppliers kits use a combination of new,and rebuilt Lonestar parts.About 90% of the PS parts,and calipers for vettes are Lonestar items outta TX.They are pretty much the same kits throughout the vette industry,and Lonestar is probably the best company out there.:cheers
If your car is a BB,then it is 900.00 shipped to your doorstep,but again,complate w/all the hardware,fluid,directions,etc.,except the belt.
Thanks,Kevin
Kevin is GREAT to deal with. We talked on the phone and he answered all of my questions and helped me understand what I was getting into. I am patiently waiting for delivery as we speak.
shmoky
PS he was also the LOWEST price I could find anywhere.
What fabrication are you talking about? Sure, if you did it like Norval did then there's a lot of fab needed. If you order a kit from corvettesteering or VB&P then there's no fab work needed. Unless you needed a stock system for judging I'd never put one back on. But if that's what you want go with vettesbydesign.
Thanks,Kevin
Have you any idea of international shipping costs I have decided to convert to power steering and was looking at the ecklers kit. I live in Ireland. Is there much difference in the standard or high performance kit?
Thanks, I was under the impression that with all the integrated kit's that brake lines had to be re-located etc and bracket frame fab was required. Are you saying these unit's bolt right in ?....just basically R&I the steering box and install the pump and hoses?
Thanks all for the input.
Kevin, I will plan to look into this. If I stick with my plan to go with stock system I'll be in touch.
You just move the 2 brakes lines over a little bit, so they don't get squashed by the box. Of course you will need a pump. You can use any pump that will bolt on correctly, don't bother with a Corvette specific as they have a lower line pressure. (unless you are using a stock system, then you must use a Corvette pump).
If you are more comfortable with the stock system then please go that way. Many people here are perfectly happy with the stock unit.
Kevin,
I saw on another post that Ecklers has a new integral Power Steering box. Can you get hold of these? If so, what price on a package of Box, standard relay rod and coupler/rag joint? Maybe also with new hoses to suit. Also, how much to freight to Australia (and Ireland)? I'd be very interested.
Kevin,
Regards from Down Under
aussiejohn
5 months to go
John....I don't know about the box.I will call my supplier here,and see what he says.He isn't the supplier for these,but would have a avenue for them for me probably.Let me see.
I will pm you,so we arn't jumping in the this guys thread.
Cheers tony
pm sent.....
I Do wanna touch on this,so everyone knows what the differences are for the standard SB,and hi-perf.The difference is in the size of the pulleys,and their apperance.These are not original GM replacement pieces,but made from the same material to look exactly like the GMs from the factory.
I have no problem shipping/mailing overseas to you guys,but will be pricey.I just spent a hundred dollar bill to get one to schmok in Canda.
I installed the Corvette Steering conversion in mine, haven't driven it yet so I can't comment on that. But, the install was very easy, just unbolted one brake line clip and pushed it over. Although the body was off at the time.
I looked at that one. You are required to switch to a manual drag link & perform some steering arm mod, which goes unspecified. So it may not seem the good deal that the price indicates. But it does look like the casting is made to fit directly, which makes for a cleaner looking install. Maybe Tom over at corvettesteering could rework these boxes for his kit. Actually the mod to a ps drag link isn't that hard. I'm sure Noval explained it somewhere.
I looked at the Borgeson unit as well and had the same concerns about the installation. no reviews posted and product has only been listed since 2/9/09. So even though the price is right I hesitate on this one.
Looking at this kit from VB&P, even though it's a pricey it looks quite attractive. Anybody have any comments on this one? Is this the concept one box? I've had good luck with VB&P in the past. I'm thinkin' this may be the way to go.
Update: Looks like Ecklers is selling the Borgeson kit with the same comments about a steering shaft modification. I'm going to try and call borgeson today and get more info on this or try and get them to share the install manual if they have one.
Reason: Update
If you want stock then by all means get that kit, but there is not any fabrication to the Jeep box to speak of. I have stock on mine (with Lonestar parts, which are very good), but if I had it to do again, I would go with the Jeep box. They drive so nicely. My .02
