Integral power steering box
Old Mar 12, 2009 | 10:16 PM
1Fordman's Avatar
1Fordman
Default Integral power steering box
Check out the new almost bolt in integral power steering box from Eckler's
Old Mar 12, 2009 | 10:43 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Saw that at another site. You still need $300 in more parts (if you PS already) & modify the steering arm???? Better off with the corvettesteering kit
Old Mar 13, 2009 | 08:25 PM
Greg G's Avatar
Greg G
Looks great. Can't wait till someone tries it and posts pictures and a review.
Old Mar 13, 2009 | 10:35 PM
RunningMan373's Avatar
RunningMan373
http://www.ecklers.com/product.asp?p...7&dept_id=1838
Old Mar 14, 2009 | 10:00 AM
SIXFOOTER's Avatar
SIXFOOTER
Why would you need to install a non PS relay rod for this?
Old Mar 14, 2009 | 11:30 AM
SteveG75's Avatar
SteveG75
Because you are getting rid of the control valve.
Old Mar 14, 2009 | 11:37 AM
Paul L's Avatar
Paul L
The rod is $190.00! That conversion could get expensive.
Old Mar 14, 2009 | 02:21 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
? So for those of us converting from manual steering this would not be an issue, correct?
Old Mar 14, 2009 | 02:47 PM
SteveG75's Avatar
SteveG75
Correct.
Old Mar 14, 2009 | 03:12 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
With the base cost of $460 plus the relay rod at $190, totaling $650 it is just less than half the price of a new rack & pinion system kit. Am curious how it compares in feel to a r&p system.
I completely replaced my CV system which solved the leak issue and did help the steering, but it is still too loose at the top/neutral for my liking.
If this gives r&p feel and control for half the price, it can't be a bad thing.
Old Mar 14, 2009 | 04:06 PM
RunningMan373
Anybody know the actual builder of this box and accessories?
Old Mar 14, 2009 | 04:47 PM
Paul L's Avatar
Paul L
I would appreciate Jim Shea's opinion on this.
Old Mar 14, 2009 | 06:51 PM
Ol Blue's Avatar
Ol Blue
2024 C3 of the Year Finalist- Unmodified
I was at the Hot Rod and Restoration show in Indy today and talked to the Borgeson rep that had a new Corvette conversion PS box on display. It looks like the one Eckler lists.
He said that it is a Remanufactured Delphi 600 PS Box that came out in 2000 and I think he said it was from a truck. According to the rep it is a 12.7:1 ratio and is variable so normal driving it isn't darty, but when parking it is 3 turns lock to lock. They cut new splines on it that will fit the Corvette pitman arm.
You have to shorten the steering shaft a little like you have to do with the Concept One box. He indicated they have installed it on big and small block mid-years and shark cars.
I'm thinking of one for my daughter's 72 LT-1.
I agree on wanting Jim Shea's take on it.
Ol Blue
Old Mar 14, 2009 | 07:03 PM
Paul L's Avatar
Paul L
Ol Blue
Call me a sceptic for now. But ready to listen.
Old Mar 18, 2009 | 08:28 AM
mailalan's Avatar
mailalan
When you say shorten the steering shaft a little you mean something other than collapsing the column like you do with the jeep box?
- Alan
Old Mar 18, 2009 | 12:35 PM
Ol Blue's Avatar
Ol Blue
As I understand it, you collapse the steering shaft by 2 inches. They guy said that there is a 6 inch normal collapse in stock form so you have 4 inches left. It sure looks like the Jeep box to me.
Ol Blue
Old Mar 18, 2009 | 04:35 PM
SIXFOOTER's Avatar
SIXFOOTER
So why not just remove the valve and cylinder, install the new box and off down the road, leave the threaded end of the existing rod there or cut it off?
Some difference in the distances on the connection points for the rod and steering arm?
Old Mar 18, 2009 | 08:33 PM
Pacha's Avatar
Pacha
I think you can remove the valve body and block the ball, as in the Corvette Steering swap, so no need for a manual rod.
If they are made by Borgeson they should be good......
Old Mar 20, 2009 | 12:00 PM
SIXFOOTER's Avatar
SIXFOOTER
Thats what I was thinking
To Integral power steering box
