To those of you that have replaced your door panels with a basic version and had to reuse your lock trim plates. As they are peened on with a washer from the factory and you pretty much lose that set up when removing them, how did you reattach the plates on the new door panel? TIA
I had the same question about the "rivets" in the door lock **** trim. I e-mailed "Corvette America" about this and they very promptly replied with the info that what looks like a rivet is really a bead of solder. They said to simply remove the bead with a soldering iron and the trim pieces should come right out. They can then be re-installed in the same manner....or with screws.
I suppose this is a plug for "Corvette America". They are more than helpful and super fast with a response. Shoot them an e-mail and see what they tell you.
I decided to purchase the panels with new lock trim installed...so I haven't actually done this process...
When I did mine I drilled out the posts and used self-tapping screws. I didn't know the posts were filled with solder, I thought they were rivets of some sort.
The 'rivets' and plate are pot-metal. If you drill into them go slowly and use lube...or they could melt. I just used some JBWeld epoxy to hold it together; I've had no problem at all. Or you could drill a bit out so the epoxy will fill the 'rivet' shank and hold better. The drill, tap, & screw approach sounds fine...but is more trouble.
Thanks for all of the replies. I was wondering how they got them rounded so nice since they are pot metal. The solder thing sounds logical. I can drill them but drilling a 3/16" post that is only about 1/4" long does not leave much room for threads. I did pick up some push nuts to try but I think I will try the solder route first.
If it gets too hot, you lose the lock plate. See if you can practice on a scrap "pot metal" piece before you work on the lock plate. Too risky for me...
We used to drill and tap the plate which is ultimately the best way to install them but time consuming too! We found that using epoxy and letting the lock **** hold the plate in place works just as well. If you grind off the **** and re-furbish the plates, the lock **** will hold them in place just fine.
