M22 question 1968
Old Mar 13, 2009 | 08:05 PM
Andrew6@TheDoubleAA's Avatar
0Andrew6@TheDoubleAA
Former Vendor
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
Originally Posted by wer2xu
ummm...he told you it had a big block in it? Did you see the car before you bought it?
yes, why?
Old Mar 13, 2009 | 08:09 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
It had a big block in it. 390 or 400hp. It should have a rear sway bar and a single fuel line.
Not a L88 car though, sorry about that.
Old Mar 13, 2009 | 08:25 PM
Former Vendor
I don't know how to tell if it has a rear sway bar or single fuel line. How can I be sure it had a big block in it?
Old Mar 13, 2009 | 08:30 PM
CCrane65's Avatar
CCrane65
It does look like there is a drain plug in your transmission pictures.
cc
Old Mar 13, 2009 | 08:32 PM
Former Vendor
cc
that was my assumption too.
Old Mar 13, 2009 | 08:33 PM
CCrane65's Avatar
CCrane65
Check my post on page one to identify if it has a sway bar.
cc
Old Mar 13, 2009 | 08:34 PM
Former Vendor
hey guys, I appreciate everyones help. I'm still very new to this and any help anyone can give me is greatly appreciated. I learn something new about this car everyday. If anyone lives in or around the Houston area and can school me I'd be greatly appreciative. (also keep lots of beer in the house usually Smithwicks')
Old Mar 13, 2009 | 08:36 PM
Former Vendor
cc
I looked earlier and couldn't honestly tell. That is not saying much though. I don't know a whole hell of alot about it.
Budman68's Avatar
Budman68
St. Jude Donor '07
Fuel line runs on the pass. side frame in the engine bay. You should be able to see it look beneath that white overflow bottle.
The rear sway bar runs from trailing arm to trailing arm, over the spare tire. Your going to have to get on your back or just shot the camera up there. Some BB didn't come with sway bars.
Just looking at your tach, you have a BB car. Either the 390 single carb 427 or 400hp car. It's not the 425hp 427.
Old Mar 13, 2009 | 08:45 PM
wer2xu's Avatar
wer2xu
appreciate the help. I'm still new to this and don't know. Guy I bought the car from told me it had an orig. big block 427 motor in it.
That made it sound like you could not tell the difference from a big block and a small block.
Old Mar 13, 2009 | 08:46 PM
Former Vendor
how do you know if its the 425 hp 427
Old Mar 13, 2009 | 08:51 PM
68L71's Avatar
68L71
cc
Looks like the fill plug to me...
Old Mar 13, 2009 | 08:53 PM
  #33
Former Vendor
ok, from what I can see doesn't look like there is a sway bar. and as far as I can tell fuel line comes from the tank and goes to the fuel pump and goes to the carb. making it a single line. If it had more than one I'd assume that would of made it a tri-power?
Old Mar 13, 2009 | 09:02 PM
  #34
Budman68's Avatar
Budman68
St. Jude Donor '07
The redline on the tach would be highier. I guess you don't want the car now.
Old Mar 13, 2009 | 09:25 PM
  #35
Former Vendor
nope going to have to just throw it away lol, I traded my 71 gto for the car and I love it just don't drive it much. I guess I baby it way too much.
Old Mar 13, 2009 | 10:09 PM
  #36
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
No no no. I think you need to do more reading some books. there are plenty of good books out there. Go to NCRS.org and look. I can see this thread going on for ever. I am no C3 expert by any means. good luck with your car.
Old Mar 13, 2009 | 10:10 PM
  #37
Nowhere Man
also I believe after 71 all muncies got a drain plug but a over the counter M22 had 2 drain plugs
To M22 question 1968
Old Mar 13, 2009 | 10:19 PM
  #38
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
......um, nobody mentioned this yet, but have you checked the numbers on the engine vs the VIN#??? Maybe this car is a smallblock car originally AND the original motor is THE one in THE car???
...what others are refering to the "two fuel lines" are that some '68s had one single line along the frame from the tank TO the fuel pump. Others had two lines from the tank to the fuel pump along the frame; a fuel supply and a smaller diameter fuel return line(spillback)to the tank.
...if this car originally had two lines, chances are very good that it still has the "double line fuel clamps" somewhere along the frame. The single line fuel clamps were unique and rarely were re-installed to take the place of the double fuel line style clamp.
Old Mar 14, 2009 | 06:44 AM
  #39
Former Vendor
The 350 that is in the car now matches numbers with a LT1 1984 truck.
Old Mar 14, 2009 | 08:03 AM
  #40
C3 4ME's Avatar
C3 4ME
The 350 may match to an 84 truck, but not an LT1, there's no such thing on a truck and definitely not in 84 on any vehicle.
