72 tmp' gauge wiring?
Old Mar 14, 2009 | 11:30 AM
avner's Avatar
avner
Default 72 tmp' gauge wiring?
Hi
I'm going to start the engine in the first time and I build a temporary stand with all the gauges I need.
I need to wire the tmp' gauge and I have three terminals you can see in the pic':
Green go to the sender.
Black go to ......???
Pink go to......???
The colors are the original harness color.
Thanks, Avner
Old Mar 14, 2009 | 11:55 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The green wire is the signal wire from your sending unit, the black is ground and the pink is 12 volt.
Willcox
Old Mar 14, 2009 | 12:06 PM
avner's Avatar
avner
Thanks Willcox
I will give the pink 12V after the key.
Now I will start new thread:
How to wire the engine for first startup?
To 72 tmp' gauge wiring?
