Replace Wiper Selonoid
Old Mar 14, 2009 | 04:45 PM
Jack Sorenson's Avatar
Jack Sorenson
Default Replace Wiper Selonoid
Do I have to drop the dash to replace the Wiper Selonoid (behind the Tack)? The selonoid has only 4 lbs of vacuum coming out and 12 lbs going in. Any tips on how to get at this to replace?
Old Mar 14, 2009 | 05:15 PM
corvetteload's Avatar
corvetteload
Might have to, It is held on with a screw with a hex head, may be able to remove plastic vent piece and get it that way. Which would require putting your legs over the seat and your head under the dash, no easy way to do it....GOOD F-ING LUCK!!!!!
Old Mar 14, 2009 | 06:12 PM
babylonvette's Avatar
babylonvette
i fit under the dash to remove mine ,it had a small bolt or 2 holding it in when i replaced it i extended the vacumn lines and put it under the console so it was easyier to get to if needed
To Replace Wiper Selonoid
