Getting the gaps right
First, you need to see the crapy work from a previous repair. Look at that bondin job!
I could fit my hand between the fender and the passenger A-pillar.
First they stripped the paint off the nose.
Then they started working on the L88 hood I gave them, getting the gaps right.
It was a lost cause, so they are working on the door gaps until the new hood shows up. Then they tried to split the old fender from the bonding strip. It was so screwed up, they replaced the top part of the fender
Then they started working on the door gaps.
They are getting closer. I gave then new hinge pins, hinge spacers, and springs to work with.
They need to add some fiberglass here.
It takes a lot of finess, to get these gaps just right. I told them to take their time, and get them right.
Those are GREAT pictures. They really explain why working on a Corvette body and getting it ready for paint can eat up some serious time and $$$, if it's done right.
Thanks for SHOWING the truth.
Regards,
Alan
I understand how you feel about the hood. I cut the l-88 cowl out of mine yesterday and threw the rest away. The thing literally just peeled apart from the frame. Hopefully i can get something out of it.....
good luck! and get some pics when it's done!
It looks like that shop has to undo a bunch of bubba work.
If so pleae respost that person's information so I can remember to steer clear of them.
One day I am going to want a hi-rise hood for my `76 to replace mine that has a hole in it for the supercharger...
In the one photo the body guy had slid the door all the way forward to get the gap better at the fender in that shot. The door opened and shut perfectly in that position but I asked him to verify the door glass will fit and seal, as well as the weatherstripping, before he did any modification to the rear fender. I beleive he will be getting the rear gap right, then working on the front fender edge to get the front gaps right.
Here are the gaps this morning. Everything looked great to me. I am super happy.
Now would also be a good time to steam clean the engine compartment and re-spray the inner wheel wells, fan shroud (if metal), and so on, BEFORE the car is painted. Just a my 2c.
Glenn
Looks like you have a good shop that is willing to work w/you,and takes pride in their work.That's the main thing.
I wish you luck on the hood, but keep pics coming with your progress!!
The car looks awesome!
I took some more pictures with my camera phone, but I didn't bring my cable with me, so it will be Monday before I can download the pictures.
The Torch Red is just breathtaking on the car.
I know, this post is worthless without pictures! I promise, you will not be disapointed on Monday!
Here you can see the color better. Above the bumper is a panel off of the actual 1969 Camaro Pace car that paced the field. You can barely see the orange stripes on the white panel. This guy paid $50,000 for the car in disassembled, but original condition. You can see the difference between the orange and the red, if you look closely.
Here's the driver's door gaps.
Here's the passenger door gaps.
It was still being buffed out in these pictures.
Here is the headlight door all finished.
The previous guy that painted my car laid so much primer in between my headlights this is what happened.
I only had the car home for a few hours after paying for a brand new paint job... talk about pissed, it got both sides.
The header brace had broken loose in the storm, when the roof pole hit the front fender and light. they re-attached the header brace in the body shop before they did any of the body work or paint, so hopefully they checked this already.
Thanks for the heads-up.
I hope your shop made good on the screw-up.
He tried to "blend" in the paint in that area and for some reason it was dark in spots....almost like there wasn't enough red over the primer. This guy eventually got hooked on meth, lost 100lbs and lost his business. I gave up on him.
I drove the car like that for almost a year before I repainted the whole car my self....it looks 10x's better than the "professional" job.
