Baking manifold paint.
Old Mar 14, 2009 | 10:25 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Baking manifold paint.
Anyone baked their manifolds like the VHT instructions tell you to do? Does it stink? 250 degrees for 30 min., 30 min. cool down, and 400 degrees for 30 min.
Old Mar 14, 2009 | 11:04 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
I popped a pair of valve covers into mama's oven. About noon. She got home from work at 4 and never knew
Odor didn't bother me or the dogs. 250 degrees for 30 minutes is all I did.
She never knew they were in the dishwasher, either!
Old Mar 15, 2009 | 01:33 AM
7T1vette's Avatar
7T1vette
Doing it at 250F only won't cure it completely; but it should get final cure when you run it on the engine for a while. Heating VHT to 400F does start to make some pretty good fumes...not sure I'd want to do it in something that will make my dinner later.
Old Mar 15, 2009 | 02:33 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Well the first cycle showed some rust marks, will recoat and start over. I sandblasted them yesterday, but the humitity was 98% so I guess some moisture was captured in the paint.
Old Mar 15, 2009 | 05:35 PM
7T1vette's Avatar
7T1vette
Yep. You have to vacuum-bag them after a thorough cleaning or paint them immediately to prevent rust from starting.
Old Mar 15, 2009 | 06:05 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Also found a crack. Will need to pick up a special welding rod for cast tomorrow.
Old Mar 15, 2009 | 08:10 PM
70Yellowbird's Avatar
70Yellowbird
So what is an alternative oven? ... do you find someone with a kiln?
Old Mar 15, 2009 | 09:04 PM
7T1vette's Avatar
7T1vette
Bake them at 250F to get them 'started'. Then install them on the car and finish the curing process using engine heat.
Old Mar 15, 2009 | 09:06 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
I used my gas pit today. It get's plenty hot, I just suggest using a pan to cook them on. I think you can get them for a couple of bucks at the grocery store.
Old Mar 15, 2009 | 09:08 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Also even at low on the pit for 30 min. the paint baked nice. It doesn't look like powercoating, but it does look harder. I would suggest more than two coats of VHT paint.
Can't wait to see what 600 degrees will look like.
Old Mar 15, 2009 | 09:18 PM
7T1vette's Avatar
7T1vette
It shouldn't look any different, but it will be more durable.
To Baking manifold paint.
