Stop lights / tail lights intermittent problem
Old Mar 17, 2009 | 05:37 PM
Power_Stroked's Avatar
Power_Stroked
8th Gear
Default Stop lights / tail lights intermittent problem
I have an 82 with a bit of a light problem. My tail/stop lights work intermittently. if i get up under the bumper and fool with the back of the lights i can get them to work for a while. So it seems to me it is a loose wire within the plug/socket of a certain light.
How have you all gone about to fix this? Is soldering the answer?
Any suggestions are welcomed. Thank you, Robert
Old Mar 19, 2009 | 11:36 AM
Lon Wayne's Avatar
Lon Wayne
I would check my GROUND,what I did when mine did not work at all after putting on A bumper.
Old Mar 19, 2009 | 01:35 PM
Power_Stroked
8th Gear
thanks for the respose.
is there a ground for each light or one for all the back lights?
thanks.
Old Mar 19, 2009 | 02:11 PM
Lon Wayne's Avatar
Lon Wayne
there should be a bolt with two or three wires going to it on the driver side rear take the wires off with the bolt and clean them up. it sounds like your problem.
Old Mar 19, 2009 | 02:22 PM
J.T.vette's Avatar
J.T.vette
I had the same problem but it was only on the left side tail light. When I removed the tail light to look at the tail light socket I noticed that when I wiggled the black wire on the socket that the light would cut on then off. I replaced the socket and the problem was fixed. I would say that your problem is somewhere in the ground in the sockets or where it grounds to the body. I hope this helps and that you can find your problem and get it fixed.
Old Mar 19, 2009 | 03:13 PM
Power_Stroked
8th Gear
j.t., i think you hit the nail on the head as that is exactly what is occurring. is there away to soder it or should i do a full replacement?
Old Mar 19, 2009 | 08:16 PM
J.T.vette's Avatar
J.T.vette
I would just replace the socket, I don't think that you can get them from a auto parts store for a 82. my car is a 79 and I got them from zips for about $20.
To Stop lights / tail lights intermittent problem
