Rebuilt Engine Is Back
Old Mar 18, 2009 | 07:12 PM
dar322's Avatar
dar322
St. Jude Donor '12-'13
Default Rebuilt Engine Is Back
http://www.flickr.com/photos/12428328@N02/3361437238/
Old Mar 18, 2009 | 07:31 PM
spedaleden's Avatar
spedaleden
Hey that looks like mine. Why did you hae to rebuild it?
Old Mar 18, 2009 | 07:39 PM
dar322's Avatar
dar322
spun bearing. went to ohio where $40 an hour goes a long ways compared to $120 around here. Rebuilt. Squared, decked, bored. 300 hp, trans rebuilt with a mild 1800 stall. Well, now I know where I can find some spare parts. How can I get this image in the post?
Old Mar 18, 2009 | 07:47 PM
Gordonm's Avatar
Gordonm
Like this.
Old Mar 18, 2009 | 08:11 PM
spedaleden's Avatar
spedaleden
Originally Posted by Gordonm
Like this.
Hey oil pressure sending unit is in the wrong place. It mounts on the top of the block right by dist. and oil temp send unit goes where they have the pressure unit. At least this is how it is on my 81
Old Mar 18, 2009 | 08:14 PM
Gordonm's Avatar
Gordonm
I just went through this. If you have the radio that gives you a clock on the radio you get the oil temp gauge and not the clock. If you have the oil temp gauge the sensor mounts down by the filter and the OP sender is on the top. If you do not have the oil temp gauge then the OP sender is down by the filter.
Old Mar 18, 2009 | 08:25 PM
dar322's Avatar
dar322
Wow I had to read that slowly Gordon. I have the clock and next to that is the oil pressure gauge. So is this where it should be?
Old Mar 18, 2009 | 08:27 PM
spedaleden's Avatar
spedaleden
I just went through this. If you have the radio that gives you a clock on the radio you get the oil temp gauge and not the clock. If you have the oil temp gauge the sensor mounts down by the filter and the OP sender is on the top. If you do not have the oil temp gauge (DO YOU MEAN CLOCK) then the OP sender is down by the filter.
I thought 1980 Clock 81 Oil temp guage. So Gordon in 1980 OP switch was monuted by filter? Learn somethingnew today.
Old Mar 18, 2009 | 09:07 PM
Gordonm's Avatar
Gordonm
That was a lot of words jammed together. I knew what I was saying but after rereading I can see some confusion.
My understanding is that when you had a radio that came with the clock on the face of the radio you got the oil temp gauge in the console gauge cluster. If the radio was the standard radio with no clock on the face of it you got the clock in theconsole cluster and no oil temp gauge. If your car had an oil temp gauge for reasons above the sensor was down by the filter and the OP gauge sender was on the top of the block. If you had the clock in the console and no oil temp gauge the OP sender was down but the oil filter. This is what I got from other forum members and my neighbor has a stock 81 with no oil temp gauge and this is how his is. Anyone with different info please correct me if I'm wrong.
Old Mar 18, 2009 | 10:43 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Gordonm has it right. Tho it's long gone, my SA's original L82 had the oil press sender down there, no temp gauge even available at the time.
Old Mar 19, 2009 | 07:04 PM
Dantana's Avatar
Dantana
Can I ask about the significance of the blue block color? Not something I have seen in the past, I'm used to orange or black or maybe match the car color...
Old Mar 19, 2009 | 07:07 PM
dar322's Avatar
dar322
mine was so dirty i didn't know it was blue either. from what i was told, gm changed to gm blue in 77.
Old Mar 19, 2009 | 07:23 PM
wfo76's Avatar
wfo76
They switched to "Corporate Blue" in 77 and this coincided when they started to install the small block Chevrolet in other GM cars (Pontiacs, Buick, etc.). I guess GM figured if they painted them Blue nobody would notice but that didn't happen. There were several lawsuits that also resulted from this. I remember reading about one where an elderly gentleman was so insulted that a Chevy engine was under the hood of his new Buick that he sued GM when the dealer refused to take it back. Shortly after that is when you will find on the window sticker the line about GM cars can use engines from different divisions or something like that.
Old Mar 19, 2009 | 09:02 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Corporate !! Paint em' Chevrolet orange! It's the right thing to do! It's signature of great performance and a symbol of Chevy heritage!
Old Mar 19, 2009 | 10:52 PM
PRATASEIS's Avatar
PRATASEIS
Corporate blew!
To Rebuilt Engine Is Back
