Help with 1968 Convertible engine Id
Old Mar 21, 2009 | 07:19 PM
longbros's Avatar
longbros
Default Help with 1968 Convertible engine Id
I just picked up a 1968 Corvette convertible. It has no engine, and I am trying to determine which engine it might have had. I have not dropped the gas tank to look for the tank sticker yet, but my guess is that the sticker is not there, as the tank looks newer. It is a 4spd car, and the tach has a redline of 6500. There is a factory sway bar in the rear. I have not checked the rear end code yet. Any help would be apprciated.
Fred
Old Mar 21, 2009 | 07:24 PM
nutsy's Avatar
nutsy
With the factory sway bar i would guess it had a 427.
Old Mar 21, 2009 | 07:28 PM
Alan 71's Avatar
Alan 71
I believe that in 1968 only 2 engines used a 6500 red line tachometer... 427/435 and 427/430.
Regards,
Alan
Old Mar 21, 2009 | 07:31 PM
longbros's Avatar
longbros
Thanks guys, those were my thoughts also. I was told by the previous owner that it had been a big block car, but the original big block was gone when he purchased it some years ago, and it had a 396 in it when he got it.
Old Mar 21, 2009 | 07:58 PM
wfo76's Avatar
wfo76
How many steel fuel lines from tank to pump?
Must be only 1 line to be L71 or L88.
2 lines means small block or 427/390.
Old Mar 22, 2009 | 04:29 PM
longbros's Avatar
longbros
Yes, it has one fuel line along the passenger side. No other lines.
Old Mar 22, 2009 | 05:23 PM
wfo76's Avatar
wfo76
That is good news on the fuel line.
Does it have power brakes?
What about an aluminum expansion tank or mounting holes on inner fender?
Also look for the Transistor Ignition amplifier box or mounting holes on left front side of radiator.
Old Mar 22, 2009 | 05:34 PM
longbros's Avatar
longbros
No power brakes. Expansion tank is gone, I will look for the holes. I will also look for the ignition amplifier box holes. Good News!!!! I think I see a tank sticker!!! Hang on!
Old Mar 22, 2009 | 06:24 PM
longbros's Avatar
longbros
This is an early 1968 car. It is within the first 325 of that year. The numbers off of the rear end housing are FB 6 23 67. From what I have been able to find out, that would indicate that this rear is dated 6/23/67 and the FB code would make it the heavy duty 4.11 big block rear. Also, I have verified that the transmission is the matching number 4spd, as it has the VIN stamped on the side.
Old Mar 22, 2009 | 09:41 PM
longbros's Avatar
longbros
Unfortunately, this car has had some modifications, including rear fender flares, and it appears the front clip was replaced long ago with a 70-72 style. So, I can not be sure about the expansion tank mounting. The radiator support is there and the only holes on the left side I see is the big one the wires/hoses might go through and one other small screw hole.
I have not dropped the gas tank yet, but may do that tomorrow. I do see what appears to be a tank sticker on top of the tank, but it does not look like the ones I have seen before and it is in a different location then I am use to. The few Corvettes I have owned have all be 1970 models, and the tank sticker was always on the drivers side and looked like a regular piece of paper glued to the tank. This sticker is on the passenger side, and has a bit of a reddish brown color. Not what I expected. Once I drop the tank, I will report what I find.
Old Mar 24, 2009 | 08:28 PM
longbros's Avatar
longbros
I dropped the tank today, no tank sticker. What I was seeing was some kind of plastic label on top of the tank. The tank is a replacement tank, although obviously replaced many years ago. So, no documentation, just the tach, sway bars, single fuel line, and caps on the half shafts to indicate it was possibly a big block car.
Old Mar 24, 2009 | 08:40 PM
wfo76's Avatar
wfo76
Evidence on the car still points to L71 or L89.
The FB coded rear end was used L71/L89/L88 only.
Good thing having the original tranny, it should be the close ratio M21.
Might not be able to go much further with the clues we have left.
Are you gonna restore it?
Old Mar 24, 2009 | 08:58 PM
longbros's Avatar
longbros
Yes, the 4spd appears to be an M21. It has the VIN stamped on the side, and has a single groove on the input shaft. I agree, not many clues left. While I had the gas tank out, I did notice the number 299 written on the baulkhead just in front of the tank. As I recall from my 70 I had years ago, the number there would match the handwritten number on the build sheet, if I had one. At this time, I have no plans for restoration. My plan at this time is to pass it on to someone else.
Old Mar 24, 2009 | 11:00 PM
longbros's Avatar
longbros
Was the front sway bar on the big block cars larger in diameter compared to small block cars? If so, what diameter front sway bar would I expect if this 68 was a big block car?
Old Mar 24, 2009 | 11:02 PM
vettebuyer6369's Avatar
vettebuyer6369
Maybe I missed it, but is there a data plate still on the shifter console?
Anything left of the emissions label on the firewall?
Old Mar 24, 2009 | 11:11 PM
longbros's Avatar
longbros
The shifter console is gone, but I still have the chrome plate that goes on top of it that holds the heater controls, ash tray, etc. No indication what the engine or HP was. The emission label is long gone.
Old Mar 24, 2009 | 11:14 PM
wfo76's Avatar
wfo76
Yes, small block was 3/4" front and nothing on the rear.
15/16" front and 9/16" rear.
Data plate 69-up only.
To Help with 1968 Convertible engine Id
Old Mar 24, 2009 | 11:18 PM
longbros's Avatar
longbros
Thanks. I will measure the front bar tomorrow. In my mind's eye, I see it as the larger one. I thought that only 69 and up had the data listed on the console, but was not sure. The chrome top plate does not seem to have a place for it so to speak as I recall.
Old Mar 24, 2009 | 11:38 PM
vettebuyer6369
Nope, nothing on '68, duh. I'm spending too much $ and thought process on the '69 these days...
Old Mar 25, 2009 | 12:19 AM
DZRick's Avatar
DZRick
68 console plate should look like this one, only painted.
