engine bay opinions?
Old Mar 21, 2009 | 11:55 PM
71coupe454's Avatar
71coupe454
Default engine bay opinions?
I got some more work to go yet. A week ago I thought I would climb in the engine compartment and spend a couple hours freshening it up with some cleaning and a couple rattle cans.. yeah right.. so much for that idea.. see pics below.. So anyways, My frame and suspension are painted gloss black, I think I want to paint the firewall and both fender wells with Satin black and then paint all the stuff that I have takin off, Gloss black, and maybe do the fake gold cad paint on all the vacumn stuff that came that way. and I have a couple new stickers for it.. Do you all think that sounds like that would look good? any other ideas or suggestions would be appreciated! And also, is the black ribbed plastic tubing stuff about the best/only way to clean up the wiring?
Old Mar 22, 2009 | 12:39 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default vette
JMO......... I would buy a quart of automotive black and shoot it with a HVLP gun. Much easier this way. Lasts longer and more durable. I would use dupont chroma base with croma clear.
Your car is stripped now. Best time to do a good job under the hood.
Old Mar 22, 2009 | 12:46 AM
71coupe454's Avatar
71coupe454
Yep I have decent new HVLP gun, Thats what I am going to do since I got carried away and stripped the dang thing out, fingers are about bleeding from the sand paper.. I spent 3-4 more hours on it after I took those pics. Whats the Chroma part of that name mean? I guess I can get it gloss and satin? or add flattener? I read something about that?
Old Mar 22, 2009 | 12:52 AM
SEVNT6's Avatar
SEVNT6
Been there, done that...... When I did my firewall I sanded & filled holes with bondo. I laid down 3 coats of primer & 3 more of Dupli-Color engine enamel in gloss black, dry sanding each coat but the last. I took out the washer hoses & bottle. Hid the headlight door vacuum lines under the brake booster. Fun Fun..............
Old Mar 22, 2009 | 12:56 AM
CorvetteMike2024
Corvette Enthusiast
Default vette
I used chroma base and chroma clear on all my cars. I prefer high gloss under the hood also. My cars are drivers and I like the duribility of the high gloss better.
Chroma base and chroma clear are basecoat clear coat system. I only use dupont paint. Very expensive but very easy to use. You get what you pay for. JMO...............
Old Mar 22, 2009 | 01:35 AM
71coupe454's Avatar
71coupe454
Dang that Gloss sure does look good. I thought satin and gloss mixed between the firewall and parts would look good but now I dunno after seeing that.
Old Mar 22, 2009 | 06:43 AM
7T1vette's Avatar
7T1vette
It's all in what you want. If you want 'original' look, use semi-flat or satin on panels and semi-gloss on components/accessories. If you want it to be a custom show car, use gloss...but the surfaces better be smooth and clean or the surface flaws will stick out like a 'sore thumb'.
Old Mar 22, 2009 | 07:40 AM
dmayhew's Avatar
dmayhew
I suggest that while you are thyere, that you remove the steening gear box and paint it a light grey.
David
Old Mar 22, 2009 | 08:34 AM
SuprJames's Avatar
SuprJames
Been there, done that as well!
Don't do it though unless you are VERY commited to getting it as smooth as possible. Otherwise, just flat black it for an original look. If you really get carried away you can get rid of the heater box and use a Hot Rod Air or Vintage kit.
Old Mar 22, 2009 | 04:05 PM
blk79nj's Avatar
blk79nj
I have never seen a pully system like that on a supercharger. That thing looks bad a$$!
Old Mar 22, 2009 | 05:04 PM
SEVNT6's Avatar
SEVNT6
VERY nice SuprJames.... And good words of wisdom. Without all of the sanding there's no way I could've used spray can gloss & had it come out smooth. Oh, nice motor too........
Old Mar 22, 2009 | 11:52 PM
SuprJames's Avatar
SuprJames
Fill, sand, fill, sand, fill, sand, fill, sand, sand, sand, and when your finger tips start bleeding, wrap them up and fill and sand some more.
Your pics make me kick myself for not painting my wiper motor silver like my gut told me. No one will notice our hard work until we park our cars in a row of stock C3's with the hood open. The difference in appearance is staggering. Looks great!!
Old Mar 23, 2009 | 12:24 AM
SEVNT6's Avatar
SEVNT6
Thanks Man. But even some C3 owners at car shows don't notice everything. Like how I drilled a hole in the firewall and ran the wires for the blower motor relay & resistor in to it so they weren't spread out all over the top of the AC box.....
Old Mar 23, 2009 | 12:33 AM
vettebuyer6369's Avatar
vettebuyer6369
Completely depends on what you are going for. You need to have a vision of what the engine compartment will look like when you are done. If you want a full custom look, the gloss is an option. If you are still giving any consideration at all to stock/original, the gloss will end that.
Old Mar 24, 2009 | 08:04 PM
71coupe454's Avatar
71coupe454
I dont think I will ever get it good enough to use gloss paint
Old Mar 24, 2009 | 10:36 PM
SuprJames's Avatar
SuprJames
Looks a lot better then mine did when I started! It is amazing how many holes are in a C3 firewall huh??
Old Mar 24, 2009 | 10:46 PM
71coupe454's Avatar
71coupe454
Yep plenty of holes, wish I would have put some thought into how I could do away with some of them before I stripped it all out. I still got tons of scratches and blemishes to get out of it but its better than what I started with a few days ago.
Old Mar 25, 2009 | 07:51 AM
SuprJames's Avatar
SuprJames
It looks great! Way better then stock.
To engine bay opinions?
