Rear window latch trim bezel redo
Old Mar 22, 2009 | 10:49 AM
GD70's Avatar
GD70
Default Rear window latch trim bezel redo
Got the bezels from a fellow forum member in Canada Saturday and stripped, primed and repainted. Small project but sometimes it's the little things that make your day and another issue to check off the list. Here's a few pics of how I received them to refinished and installed. Even with primer and 4 coats of paint, they still chip very easily and needed to do some small touch ups. Still, looks 100 times better now.
Glenn
Old Mar 22, 2009 | 10:53 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Great job, your right GD70, it's the little things.
Old Mar 22, 2009 | 10:55 AM
rydoc's Avatar
rydoc
Looks good...
I enjoy doing all the little stuff
Rod
Old Mar 22, 2009 | 10:56 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Nice work. Its all the little details that help it all come together. Have fun with it.
Old Mar 22, 2009 | 11:06 AM
GD70's Avatar
GD70
Thanks guys! I have a laundry list of small stuff to do. Some things you won't even see, but in my mind once it's done & correct, I feel good.
Old Mar 22, 2009 | 01:09 PM
70Donnybrooke's Avatar
70Donnybrooke
Mine could also use a good painting. The problem I have is they are saddle. Where do you get paint to do them? Places sell interior paint, but can you use that on the metal pieces or is it just for flexible interior pieces.
Old Mar 22, 2009 | 01:36 PM
GD70's Avatar
GD70
In the new Corvette Central catalog on p.133 they sell interior color paint, 15.95 for a 16 oz. aerosol can. I would guess other vendors have similar paints or "dye"as well. You should call to confirm it will work for your need.
Old Mar 22, 2009 | 02:32 PM
70Yellowbird's Avatar
70Yellowbird
As you probably already know, many vendors interchange what they call interior 'paint' with interior 'dye'. When I have asked vendors what they are really selling, they have told me that it is really dye (for the plastics and vinyl), and that it's okay to use it on metals, but it doesn't stick like paint does, and therefore not very durable.
That said, I am planning in taking a sample of my saddle interior to a auto paint supply store and have them match the color for a couple of rattle cans of metal paint.
Good luck.
Old Mar 22, 2009 | 02:34 PM
Alan 71's Avatar
Alan 71
Hi GD70,
It's strange but I have some of the same 'wire hooks' in my backyard as you have hanging off your post. Some of them even have the same 'clearance curve' bent into them.
Regards,
Alan
Old Mar 22, 2009 | 02:35 PM
70Yellowbird
Glenn ... nice job on your little project ... and I like the drying rack!
To Rear window latch trim bezel redo
