gas leak
Old Mar 30, 2009 | 10:40 PM
babylonvette's Avatar
babylonvette
Default gas leak
i used the 72 today and noticed a slight fuel smell, i decided that the plug in front of the original carb is the culpret,is there a way to fix it or do i have to ship to a rebuilder and hope , i remember back in the day the little plugs used to leak or fall out ,its a quadrajet, and the plug is in the front at the fuel bowl about 1/2 " in size
Old Mar 30, 2009 | 11:21 PM
Smadoo's Avatar
Smadoo
do you mean where the fuel line enters the carb? If thats where youre talking about, you can get larger self taping fittings that can stop the leek.
Old Mar 31, 2009 | 07:48 AM
babylonvette
no,on the opposite side there is a little plug ,it looks similar to a freezeout plug ,it appears to be weeping fuel ,i was wonderin how to reseal it or ship to the rebuilder and hope he can fix it
Old Mar 31, 2009 | 09:36 AM
65747785's Avatar
65747785
Try a little epoxy, after the area is cleaned and dry of course.
Old Mar 31, 2009 | 04:48 PM
doctorgene's Avatar
doctorgene
Yes Sir; Isn't that the Air adjustment on the Q. Jet?? I think that there is an O-ring on that, look at a break down of carb. I wouldn't put epoxy in it just yet, you will ruin any hope of rebuild if you do. Come on one of you carb guys, help this guy out. Doctorgene
Old Mar 31, 2009 | 11:32 PM
70BBvert's Avatar
70BBvert
Artie
Can you post a picture? That would help
Jim
To gas leak
