Converting to power windows ?
Old Apr 2, 2009 | 07:19 PM
Gordonm's Avatar
Gordonm
Default Converting to power windows ?
I am just not right. I have not even finished up this winters mods and already thinking about what to do next. I have always wanted power windows in the car. Is it better to gather all the parts or just buy all new stuff and be done with it. I know I have to replace the door panels also. Do I hunt for junk at Carlisle or just buy new. What have you guys done.
Old Apr 2, 2009 | 07:32 PM
RIO68's Avatar
RIO68
Default p/windows
There are many junk doors or should be to get some parts from. It's a crap shoot as to getting good used stuff and getting bad. Hardware in the doors can be questionable for sure--regulators that are sloppy are a nightmare. Check you money supply and then decide--tight get as much used as possible--not too tight buy new. My 2 cents?
Old Apr 2, 2009 | 08:29 PM
lethalassault's Avatar
lethalassault
Hi Gordan!
I need to do this mod to. Im with you!
The car is almost done! I will keep you posted.
Old Apr 2, 2009 | 08:44 PM
Gordonm's Avatar
Gordonm
Originally Posted by lethalassault
Hi Gordan!
I just have to redo my fuel lines. I have run the FI for short runs only. Should only be another week or two.
Old Apr 3, 2009 | 09:29 AM
MakoShark72's Avatar
MakoShark72
Hi Gordan!
Me too...
Old Apr 3, 2009 | 10:11 AM
mrvette's Avatar
mrvette
ONE of the first mods some 15 years ago, the tracks don't change, just the regulator and add the motor, but one thing you have to do is take it ALL outta there, and soak the tracks in a pan of gasoline overnight to get that damn dried up grease outta there....I did not need any nylon, put it together DRY, NO GREASE except in the motor gear and of course the regulator, that sector gear needs be well greased to not rust any, I seen them totaled with rust....
the motor/gear assy is a common generic GM found in any car of the era...junkyard 5 bux each....get the connector to them also, that varies a bit.....
AS I RECALL, I got my regulators from Yogi Bear's....
Old Apr 3, 2009 | 10:18 AM
7T1vette's Avatar
7T1vette
If money is an issue [when is it not?], you might want to do some "fact gathering" before you just jump into it. Find out what areas of the p/w components are the "wear areas". Also determine which of those cannot be repaired easily or are too costly to fix. Then, you can start checking out salvage yards and/or swap meets for p/w components...making certain that those parts don't have any of those 'high risk' problems on them. Also, take an ohmeter with you. Find out what resistance the p/w motors have and check them before you buy. If the windings are good [per ohmeter], you can fix just about any drive motor with new brushes & bushings. But, if you want to do this quickly, just shell out the money for new stuff and then you don't [or, at least, shouldn't] have to worry about condition of the stuff.
Old Apr 3, 2009 | 11:03 AM
Ganey's Avatar
Ganey
PW is the only luxury item I've ever cared about in a car.
The factory PW system is very reliable. Motors could pass as starters for mini motor cars. All I have replaced is the main reg. gear & motor mount on dr. side. Common, a stronger reg. gear & mount are avail. from the major vendors. No el. issues.
One time there was a topic on PW & several had fixed their el. problems by cleaning switches, connections & one guy cleaned inside motor.
While I like the location of the PW switches, it might be possible to mount in crank position.
Old Apr 3, 2009 | 03:12 PM
Gordonm's Avatar
Gordonm
This is not something that will be done right away. Maybe next winters project so I have time to gather parts. The problem with some parts is yo uend up buying them and by the time you rebuild them it costs about the same. I'll look into this. I did have all my door stuff out 2 years ago and cleaned out all the old grease and crap so the channels are good to go.
Old Apr 3, 2009 | 05:53 PM
Red 71's Avatar
Red 71
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
Do some research on some of the sites that offer parts for restoring old cars. I have seen power window kits that hook the switch up to your existing crank. Then you just raise or lower the crank to move the window. Would save the price of panels which might cover a good part of the cost of the power windows. I will do some looking also and will let you know what I find.
Here is one that I remembered that I have bought street rod stuff from in the past.
http://www.rockyhinge.com/
Old Apr 3, 2009 | 09:10 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
There's always the Red Green option in the mean time.
Old Apr 3, 2009 | 09:47 PM
Richard454's Avatar
Richard454
Cheap power window conversion.....
http://www.youtube.com/watch?v=lFXU43-Jgeo
I think Eckler's has the complete "factory" conversion- but it's priced at over $600
I was looking at the Electric-Life pieces-They have them for just about every car except Vettes. For a Gen 1 Camaro- a set is like around $300.
http://electric-life.com/index.asp
Then there is SPAL pieces-basically a drive system that uses the stock mech system. A pair is around $125.
Richard
Old Apr 4, 2009 | 06:08 PM
71406's Avatar
71406
You can save your current door panels by installing some of these from a 78 camaro.
http://cgi.ebay.com/ebaymotors/78-79...01159008r20947
Thats what I did when I bought used door panels that had holes for crank windows. I found some vette emblems designed for center caps that covered any evidence that they were once on a camaro.
Old Apr 4, 2009 | 06:29 PM
Gordonm's Avatar
Gordonm
[QUOTE=71406;1569574520]You can save your current door panels by installing some of these from a 78 camaro.
That is what I was thinking. My door panels are excellent and would hate to replace them. I was thinking along those lines of something to cover the holes. Great idea.
Old Apr 4, 2009 | 10:09 PM
7T1vette's Avatar
7T1vette
Or, just leave them as crank windows. How often do you need to rasie/lower them?
Old Apr 5, 2009 | 07:27 AM
Gordonm's Avatar
Gordonm
Good point.
With the 5 point harness I can't reach the window crank.
To Converting to power windows ?
