Motive Speed Bleeder
Old Apr 6, 2009 | 02:32 PM
spedaleden's Avatar
spedaleden
Default Motive Speed Bleeder
Hey , just bought one of these. I have to do brakes on my brother in laws C4. I also bought adapter for my C3.
Hope this works as good as they say.
Old Apr 6, 2009 | 03:00 PM
Duke94's Avatar
Duke94
Just make sure you use a big C-clamp to hold it down on the C3 MC and you won't have any issues. Pitch the chains that come with it.
Gary
Old Apr 6, 2009 | 03:20 PM
rcread's Avatar
rcread
Yes, the chains will cause frustration and won't allow a seal on the master cylinder. Other than that, it works great. I wish I'd have bought one when I bought my '71 13 years ago.
Old Apr 6, 2009 | 05:21 PM
RunningMan373's Avatar
RunningMan373
Gary
Old Apr 6, 2009 | 06:24 PM
TimAT's Avatar
TimAT
Depending on how good you are at estimating, try using the bleeder without putting any fluid in it. Especially when you have a m/c you can see the level in. I did my pickup and there was no mess and no spilled fluid.
Another good trick is to install the top on the m/c and pressurize the system before you put any fluid in the bleeder. Make sure it's sealed to the m/c.
Old Apr 6, 2009 | 09:49 PM
spedaleden's Avatar
spedaleden
Thanks for the tips everyone. I will let you know how I do.
Old Apr 7, 2009 | 11:25 AM
MN-Brent's Avatar
MN-Brent
Yep-they work as advertised.
You only need to pump it up to ~15PSIG
Keep it dry. Use a wood block and a C-clamp to hold the seal to the MC.
Refill after each individual bleeder purge. Just slowly loosen the C-clamp and the remaining pressure will release. Top off MC and re-clamp. Then go bleed the next corner or bleeder.
Since you are refilling the MC for each bleeder, it requires 2x refills per rear caliper.
Old Apr 7, 2009 | 12:17 PM
hicswa's Avatar
hicswa
Put a rag over that sucker in case it lets loose. Paint and brake fuild don't like each other.
Danny
Old Apr 7, 2009 | 04:26 PM
spedaleden's Avatar
spedaleden
Danny
Thanks but I am using Silicone fluid Dot 5. I'm not going to place fluid in container. I'm just going to use it for pressure.
Can't wait to try it.
Old Apr 7, 2009 | 04:47 PM
Gordonm's Avatar
Gordonm
I used the Motive bleeder for a few times and it worked great. I then proceded to break off the nipple on the front. I never replaced it. I am now using a piece of flat steel with a hole drilled and tapped. I screwed in a spare air fitting and used the rubber gasket from my Motive bleeder. I C clamp it on to the master. I set the regulater to 10 to 15 psi and plug in the air line. This works very well. Yes I have to keep checking the master so not to run out of fluid but I use a clear jar and now know how much it takes before I run the master dry. The MOtive bleeder is a great tool but there is some other options. I just used a piece of spare 1/4 plate steel.
Old Apr 7, 2009 | 05:44 PM
RunningMan373
To Motive Speed Bleeder
