Outer Door Handle Replacement
Old Apr 9, 2009 | 10:10 AM
senorv47's Avatar
senorv47
Default Outer Door Handle Replacement
This issue is driving me crazy, does anyone know the secret handshake on replacing the outer door handle on my C3? took the door panel off and WOW, how am I supposed to get to the nuts that hold it to the door? Once I can get that done then the rest should be a piece of cake right?
Old Apr 9, 2009 | 10:17 AM
GTR1999's Avatar
GTR1999
remove the latch, clean and lube it, then you can reach in to get to the 2 nuts.
Old Apr 9, 2009 | 10:21 AM
C3 4ME's Avatar
C3 4ME
yup, unscrew the 3 screws on the back of the door that hold the latch. Once it drops down, then you have much better access to the 2 nuts that hold the door handle on. After doing that, it wasn't a hard process at all to replace mine.
Old Apr 9, 2009 | 11:32 AM
halfmoontrail's Avatar
halfmoontrail
Buy a NOS or expensive GM-authorized replacement, or a good used OEM one, you don't want to have to do it again soon.
The 3 screws on the door jamb is the secret trick.
Steve
Old Apr 9, 2009 | 02:07 PM
VeroL81's Avatar
VeroL81
Halfmoontrail - Did you have a bad experience with the cheap handles? I was thinking about buying the GM handle for the driver's side and the cheap one for the passenger side.
...Alan K.
Old Apr 9, 2009 | 02:11 PM
justanotherdoe's Avatar
justanotherdoe
I put a cheap one in the drivers side of my daily driver 3 years ago. Just like the bunny, it's still going......
Old Apr 9, 2009 | 03:47 PM
halfmoontrail
...Alan K.
Alan,
Nope, but have heard horror stories. I was fortunate enough to find NOS from a local guy at the same cost as the repro.
The replacement is a b*tch even with the secret formula, and so many of the handles (OEM AND Repro) get limp; that's why I made the suggestion. One old-timer told me the easy way to tell the difference is in weight -- the OEM are much heavier than the repops.
Steve
Old Apr 9, 2009 | 04:30 PM
Tinkerbell_in_Texas's Avatar
Tinkerbell_in_Texas
St. Jude Donor '08-'09-'10-'11-'12, '14
I'm still waiting for a gm driver's side handle........after 9 months!
Old Apr 9, 2009 | 04:51 PM
VeroL81's Avatar
VeroL81
I'm gonna take a chance and buy the repros - we drive our '81 twice a week. I would think a cheap handle could survive THAT much abuse! Besides, I was told it was a "bitch" to replace the light switch - it took me about ten minutes and was no problem.
My confidence is high switching out the door handles will go smoothly!
...Alan K.
Old Apr 9, 2009 | 05:06 PM
dobroman2001's Avatar
dobroman2001
So is everybody saying that the ones from Trim Parts are OK Repo's?
http://willcoxcorvette.com/product_i...oducts_id=6199
I sure hope so!!
Old Apr 9, 2009 | 05:16 PM
GD70's Avatar
GD70
Before you go buy a new one, thoroughly clean the ones you have now. Unless it's actually broken, the original should work perfectly after being cleaned and lubed. I did this to both of mine and are now smooth as silk.
Glenn
Old Apr 13, 2009 | 01:14 PM
senorv47's Avatar
senorv47
Default RE: Door Handle Replacement
Thanks to all for the tips, right now I put in a helper spring to keep the door handle up until it gets warmer around here and I can take my time doing it
Thanks again
To Outer Door Handle Replacement
