Use old engine oil?
Old Apr 11, 2009 | 09:34 PM
rajsid's Avatar
rajsid
Default Use old engine oil?
Do you guys use engine oil that has been opened and sitting around for 4 months?
I know that it's not good to use old opened brake fluid. Just wodering of the same rule applies for engine oil too.
Old Apr 11, 2009 | 09:41 PM
dannyman's Avatar
dannyman
Absolutely, without question! As long as the container was not left open where rain or contamination could get into it!
Old Apr 11, 2009 | 09:45 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Motor oil shelf life in a closed container is a very long time. Use it, at least in the mower...
Old Apr 11, 2009 | 09:49 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I have no problem using oil that has been setting on the shelf for a while like that. As a matter of fact I buy to 5 quart jugs when I change the oil in my Z because it takes 6 quarts to fill it. I keep using the partial 5 quart jug until it is gone.
Old Apr 11, 2009 | 10:26 PM
longbros's Avatar
longbros
The problem with regular brake fluid is that it absorbs moisture after being opened. The oil will be fine, no problem.
Old Apr 11, 2009 | 11:26 PM
rajsid's Avatar
rajsid
Thanks all...
Old Apr 12, 2009 | 12:46 PM
bj1k's Avatar
bj1k
Even the notion of brake fluid going bad is exaggerated. How often do you change the brake fluid in your master cylinder ? It can sit on the shelf a reasonably long time once the seal is broken as long as you keep the cap on tight and don't let moisture get in it. With oil, I don't even know if there is an expiration time. Just common sense.
Old Apr 12, 2009 | 08:08 PM
chris75stingray's Avatar
chris75stingray
it's been in the ground for millions of years i think it will last on the shelf for a while
Old Apr 12, 2009 | 09:47 PM
dannyman's Avatar
dannyman
Now that is too funny!
Old Apr 12, 2009 | 10:30 PM
ridge's Avatar
ridge
very true.. as long as moisture does not get in the brake fluid it is fine.. if it does get in you dont want to mess with
To Use old engine oil?
