1970 454 correct spark plug
Old Apr 12, 2009 | 12:24 AM
turbojet's Avatar
turbojet
Default 1970 454 correct spark plug
As the title states what is the correct spark plug for a bone stock 1970 454/390 hp motor and where is the best place to by them and if I can"t find these whats the best replacement. Thanks
Old Apr 12, 2009 | 12:28 PM
Jeff_Keryk's Avatar
Jeff_Keryk
70 454 390 came with AC R43T, gap .035". Get 'em anywhere, like Napa or Dealer. I like Autolites; cross reference 25. Either one should be cheap. I don't use fancy plugs.
Old Apr 12, 2009 | 02:53 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
You may like a 5 heat range plug better. I find it a little more responsive in both my small blocks and my big block. In my 68 427/390 I run AC R45XLS and the car really likes it. If your engine is bone stock you should not have any problem with an extended tip plug.
Old Apr 12, 2009 | 04:40 PM
72ls5fla's Avatar
72ls5fla
I thought the R44t R43T plugs were tappered?
They don't use a washer on the bottom.
The XLS plus use a washer adn are designed for non tappered seat.
I think they were used on the 71 LS6 engine and the 1970 LS6/LS7.
I can't speak for BB engines 1969 and prior.
Old Apr 12, 2009 | 07:55 PM
early shark's Avatar
early shark
They wouldn't be used on a 1970 LS6, but appropriate for the other two applications.
To 1970 454 correct spark plug
