air vent on hood
Old Apr 12, 2009 | 05:34 PM
timd02's Avatar
timd02
Default air vent on hood
What is the little air vent on the hood with the selonoid hooked to it? I took my hood off for paint prep and the wire was still attached but the selonoid was broken from the mounting. What is this for and are there any parts for repair?
Old Apr 12, 2009 | 05:51 PM
SEVNT6's Avatar
SEVNT6
'75s had cowl induction that drew air from the back of the hood. Do you have an air cleaner with a rubber seal around the top?
Old Apr 12, 2009 | 05:57 PM
timd02's Avatar
timd02
I do. What do you do if you don't want to hook it back up? Do you take the doors out and bolt the other part back to the under side of the hood?
Old Apr 12, 2009 | 06:15 PM
SEVNT6's Avatar
SEVNT6
It's been awhile since I've seen a '75 set-up, but I would think you could take 'em out or leave them in. It would be a little louder with them out..........
Old Apr 12, 2009 | 09:21 PM
7T1vette's Avatar
7T1vette
The solenoid is wired to a switch on the accel pedal [I think], so that the door opens when you have WOT condition.
Old Apr 12, 2009 | 10:36 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
If your keeping the car inside and not driving in a lot of bad weather, I would just take it all off. Thats what i did. You get the cold air intake all the time not just at WOT and it's one less thing to break!
Old Apr 15, 2009 | 04:26 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
I wanted as much air as I could get all the time so I took my door all the way out (it still works)I then hooked a red tail light to the wires so when I really get into it the red light comes on it looks cool (if your in the car).Take it out but keep the parts and put the screen back on.
Old Nov 26, 2010 | 05:59 PM
mcltcb's Avatar
mcltcb
where are the wires for the air induction? mine was disconnected when I got the car.The wires are in place at the pedal but at the hood there are no wires.should they be in wire harness down by headlights or what? I want mine working properly.
Old Nov 26, 2010 | 06:08 PM
offaxis's Avatar
offaxis
Hey LON,
Do you have a pic of your hood with the lights on? It looks like my hood on my 78 has the same cutout underneath. Has anybody ever redone their hood to work?
Old Nov 26, 2010 | 07:16 PM
corvetteload's Avatar
corvetteload
by the appropriate AIM for your year, all wiring and routing is shown!!!
To air vent on hood
