fuel guage
Old Apr 20, 2009 | 08:31 PM
csl's Avatar
csl
Default fuel guage
I am the new owener of a 1979 vette. The fuel guage does not work. Is there a way to tell if it is the guage itself or something else in the wiring to the fuel tank?
Old Apr 20, 2009 | 10:16 PM
TimAT's Avatar
TimAT
get a 12v testlight at your local auto parts store- disconnect the gauge wire at the tank, put the light between the wiire and a good ground, turn the key on. If the gauge goes to 1/2 scale, it's the sender or tank ground. The bulb in the light should glow. Not very bright, that tells you the gauge and the wiring are ok.
Old Apr 20, 2009 | 10:40 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
You can pull the whole shebang out of the filler hole. On mine, the resistor on the float had been shellacked with old varnish from gasoline aging. I cleaned it up and my gauge now works most of the time.
Old Apr 21, 2009 | 10:11 AM
08vycpe's Avatar
08vycpe
It's nice to have a big hole for a filler but be careful!
The fumes from a spoonful of gasoline has the explosive power of 1/4 stick of dynomite. The only way I would be pulling things out of my gas tank is if the tank had been emptied and everything evaporated out or purging the tank with an inert gas after emptying it. Any kind of spark whether static electricity or from the car electrical system can ruin you, your car and your garage in a split second.
Old Apr 21, 2009 | 12:43 PM
Ak. Mal's Avatar
Ak. Mal
That seems a little far fetched to me. Can you verify that statement?
Old Apr 21, 2009 | 02:46 PM
08vycpe's Avatar
08vycpe
No I can't. Just a rumor I heard somewhere. The point I was trying to make is that a near empty car gas tank can hold a lot of fuel vapor that can kill you and burn the house down if ignited by a spark from anywhere. These early C3's with the open system, no flap, no check valve and the large mouth filler that you can stick your hand into can be dangerous. Just be careful.
When I was 14, my 14 year old friend was killed by rolling an empty barrel of gasoline across his back yard after his dad had used it to fill the boat. The barrel exploded and took the left side of his head off.
Old Apr 21, 2009 | 03:03 PM
78VetteChic's Avatar
78VetteChic
This article on Fuel Sending Unit Repair might help -
http://www.hunt4cleanair.net/Article...nitRestore.pdf
Here's my post over at Tech/Performance from this past weekend regarding the problem I found and repaired.
http://forums.corvetteforum.com/c3-t...you-think.html
Also try searching "fuel gauge" (with the quotes) for previous posts on this subject - there's been lots of posts with great info, which is how I figured out how to narrow down why my fuel gauge was possessed.
Old Apr 21, 2009 | 04:10 PM
TimAT's Avatar
TimAT
Does this work for you?
http://www.burnsurgery.org/Documents...ine_safety.doc
I remember 2nd grade- The local Fire Department did a demo for the class. 2 DROPS of gas in a 18" long 2" diameter steel pipe with a big cork and and a spark plug in the side of it. Blew the cork thru the ceiling tile in the classroom.
Old Sep 26, 2009 | 07:00 AM
csl's Avatar
csl
I am finally ready to find out if it is the guage or the sending unit. How do I know which is the guage wire at the tank?
Old Sep 26, 2009 | 11:45 AM
Ak. Mal's Avatar
Ak. Mal
There is only one wire on the sending unit. It's a ground wire. That's how the system works, it measures resistance to ground. 0 ohms = no resistance = empty tank. 90 ohms = full resistance = full tank.
Old Sep 26, 2009 | 02:12 PM
ED79's Avatar
ED79
Ok, at the tank sending unit there will be a black ground wire and a pink wire.
1. make sure gauge fuse at fuse box is good
2. turn switch on, do not start
3. unhook the pink wire at the tank, fuel gauge should go to 3 o'clock
4. ground pink wire at tank and the fuel gauge should go to empty
5. if this works, your gauge is good ED79
Old Sep 26, 2009 | 08:16 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
There was a recent post on the fuel gauges in the Tech and performance section. The title was the gauge bounces but it turned in to a gauge won't work problem. It covers a ton of info on the fuel guages.
http://forums.corvetteforum.com/c3-t...e-bounces.html
Also.. Here is a step by step manual on how to diagnosis any fuel gauge problem 77-82.
http://willcoxcorvette.com/repairand...lp.php?hID=277
If you can't figure it out, just post again.
Willcox Inc.
To fuel guage
