help me pinpoint a leak?
here's the approx location under the car:this is under the engine mind you:
and here's a short video of the drip (DONT KILL MY BANDWIDTH :P )
its not ALWAYS dripping, just after a drive and it looks like its coming from the engine... any help is appreciated
btw, the fluid is a slight brownish color and doesnt have any smell
p.s.: i KNOW the car is dirty underneath, i'll get to cleaning it when im installing the new engine in it.
and it is water based, doesnt smell like anyhting
if its a brown color, your coolant probably needs changing anyway.
That looks like a water pump seal leaking. Grab the fan (engine not running) and see if there is any play when you move the fan up and down, also side to side.Hope this helps....Tim
by the way, its DEFINITELY not from the top of the engine, looking from the top, i cant see anything...
will do (will be home in like 4 hours) and ill let you know!
Good Luck Tim
