Clutch Fork Boot Replacement - ?
Old Apr 26, 2009 | 01:12 PM
70Yellowbird's Avatar
70Yellowbird
Default Clutch Fork Boot Replacement - ?
While detailing my engine bay, I noticed that my original clutch fork boot is split in half.
I'm just wondering if replacing it is as easy as it looks. Anything special I should know before I go ahead?
Thanks.
Old Apr 26, 2009 | 01:32 PM
Duke94's Avatar
Duke94
Since you'll need to remove the Z-bar adjustment pivot from the link, measure where it is on the shaft before you remove it so you can get it back in the same place later.
Gary
Old Apr 26, 2009 | 03:33 PM
Alan 71's Avatar
Alan 71
I believe the Z-bar and clutch rod can stay together. Just the clevis pin and 1 spring need to be pulled from the clutch fork to replace the rubber fork boot.
Regards,
Alan
Old Apr 26, 2009 | 04:08 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Regards,
Alan
Yep, I got mine apart right now.
Old Apr 26, 2009 | 09:53 PM
70Yellowbird
Thanks for the info ... the boot was out in only a minute.
Now all I gotta do is find a replacement ... I see that it's a vette vendor catalog item.
Is that the normal source or can it be purchased locally?
Old Apr 27, 2009 | 04:52 PM
Alan 71's Avatar
Alan 71
I'd think it was the same on zillions of Chevrolets. Might still be a Dealer Parts Department item.
Regards,
Alan
To Clutch Fork Boot Replacement - ?
