Bumper help
Old Apr 26, 2009 | 05:53 PM
rayluka's Avatar
rayluka
Default Bumper help
Preparing to glass the bumper on to the body. What are the best products to use to bond and fill. I have searched and heard all the horror stories regarding fit and all. Just want to use the good stuff to get the best job. TIA
Old Apr 26, 2009 | 08:13 PM
rayluka's Avatar
rayluka
Maybe I should post this in the body section.
Old Apr 27, 2009 | 01:15 PM
saudivette's Avatar
saudivette
Is there a body section?
I will soon be bonding my new rear bumper to the car and filling the join line. Make sure that both surfaces are clean but roughed up, hang the bumper on the with the T bolts and nuts leaving a bit of a gap. Apply 3M8115 panel bonding adhesive into the gap and bolt the bumper up.
After the full cure time (24hours) grind a bit of a V into your join line and fill with more 8115.
That what you were after?
Old Apr 28, 2009 | 02:40 PM
rayluka's Avatar
rayluka
Ya. I found a family member with the skills. I was interested in the type of stuff to bond. So yes that is the answer I was looking for
Old Apr 28, 2009 | 03:23 PM
halfmoontrail's Avatar
halfmoontrail
What he said.
But, I like Lord Fusor 148. Also, I'm assuming you are bonding and blending fiberglass bumper covers...trying to do this with urethane bumper covers is not recommended.
Steve
Old Apr 28, 2009 | 03:59 PM
saudivette's Avatar
saudivette
Originally Posted by halfmoontrail
What he said.
Steve
Good call
Old May 5, 2009 | 01:56 PM
rayluka's Avatar
rayluka
Im using the tru flex. I should have gotten just the regular glass one. The tru flex is actually fairly firm. I made some mounting plates with steel. I tapped them and put a screw thru it. This will get a bolt on the inside (backside). Whats the working time on the products you mentioned?
Old May 5, 2009 | 02:32 PM
saudivette's Avatar
saudivette
The 3M8115 has a 90 minute working time, 4 hour handling time and a 24 hour cure time. You can accelerate the handling and cure time with heat...
Old May 5, 2009 | 02:50 PM
rayluka's Avatar
rayluka
Old May 6, 2009 | 10:03 AM
saudivette's Avatar
saudivette
No probs mate
To Bumper help
