1971 power brake conversion
Old May 4, 2009 | 11:08 PM
1971 LT-1's Avatar
1971 LT-1
Default 1971 power brake conversion
I'm looking to put power brakes onto a non-power original car. What should be looking out for and what parts will I need? Any help would be appreciated.
Al
Old May 4, 2009 | 11:34 PM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
I can't help you much on the conversion, but the manual brakes on my 71 are better than the power brakes on my 72.
New calipers, hoses, fluid. and new master cylinder are all it took to get the brakes to stop the car on a dime with VERY little pedal travel.
Old May 4, 2009 | 11:43 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Besides obviously needing a booster, you'll need a different master cylinder and push rod. The fun is in properly enlarging the hole in the firewall. The booster's position requires changing which hole the push rod clevis attaches to on the brake pedal. Highly suggest you get an AIM for your year so you can get some good views of what you're trying to accomplish.
TSW
Old May 4, 2009 | 11:53 PM
blueray72's Avatar
blueray72
TSW
I wonder if you have to do this for the hydro boost?
Old May 5, 2009 | 12:27 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I did a post on what you needed and even posted a picture a few months ago. I'll look and see if I can find it and post a link. If not, tomorrow. . . I'll do it for you over again.
Willcox.
Old May 5, 2009 | 12:31 AM
TheSkunkWorks
Willcox.
Do you sell the manual and/or PB push rods? I know some have said one or both of them have gotten hard to find.
Old May 5, 2009 | 02:12 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I did a hydroboost conversion in my '71 with manual brakes. Best mod I've ever done to the car, simply makes it so drivable.
Old May 5, 2009 | 06:48 AM
Gordonm's Avatar
Gordonm
No. There is no firewall mods when you go with a Hydroboost.
Old May 5, 2009 | 10:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 1971 LT-1
...what parts will I need? Any help would be appreciated....
Purchase the '71 assembly instruction manual (AIM) and compare the stock set up to the optional power brake set up. The AIM will list those parts which are the same as the non-power installation and will show the parts and original part numbers for parts the PB system requires. If memory serves, the PB installation requires a different size hole to be cut in the cowl, also in the AIM.
Old May 5, 2009 | 01:36 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Well, unless you'll keep the same pedal to rod leverage as the manual brakes (which is a bad idea), you have to do a minor mod. to the firewall as in this pic :
Old May 5, 2009 | 02:13 PM
Gordonm's Avatar
Gordonm
I did not have to modify anything in mine. With the proper linkage and bracket it fits without any mods.
Old May 5, 2009 | 02:15 PM
blueray72's Avatar
blueray72
.....and you're going to want to pull the drivers seat out....
Old May 5, 2009 | 04:35 PM
Theiskell's Avatar
Theiskell
Was your car a manual or power break originally? I had to cut my firewall like HamadUP. I have seen some adaptors that angel the HB up to allow for pedal alignment. Is that how you did yours?
Old May 5, 2009 | 05:24 PM
Gordonm's Avatar
Gordonm
Mine was a manual car and it is pretty flat. I would say it is not angled. Any angle it would hit the hood.
Old May 5, 2009 | 08:05 PM
98IndyPacer's Avatar
98IndyPacer
Willcox.
Here is the info.
http://forums.corvetteforum.com/c3-t...-70-vette.html
Old May 6, 2009 | 10:45 AM
7T1vette's Avatar
7T1vette
Willcox: {since you don't receive PM's}
Your write-ups are appreciated. Suggestion: Create them in a word processor program so that you can save them. Then just cut-n-paste them into your posts. That way you can retain and re-send when you need, rather than have to re-create them. (since we can't always retrieve them from the CF archives)
To 1971 power brake conversion
