replace or restore?
Old May 3, 2009 | 03:49 PM
angeleyes13760's Avatar
angeleyes13760
2nd Gear
Default replace or restore?
Iam redoing a 1978 silver anniv., I gave it to my son and we are restoring the interior, the question i have is does anyone know of replacement seats that fit with no problems or is it advised to recondition the originals,the drivers side needs some repair wrk. I am looking for the least exspensive way at this time,Iwas told alot of after mkt. seats are a hassle installing, any help would be "GREATLY",appreciated.--------thanks
Old May 3, 2009 | 04:02 PM
Gordonm's Avatar
Gordonm
The 78 and later seats were some of the better C3 seats that were made. A lot of the aftermarket seats are to wide for the Corvette. I would redo what you have and keep them in the car.
Old May 3, 2009 | 04:16 PM
7T1vette's Avatar
7T1vette
The least expensive way to redo an interior is to "recondition" it. Unless components are broken, severely cracked, torn, gouged, or ripped (to the point that a repair will be easily noticible), re-dyeing faded/worn surfaces and re-stuffing foam/cushions is the way to go. If the seat covers are not worn through, vinyl or leather can be cleaned, softened [in the case of leather], and re-colored [with the correct product] to make them look new. DO NOT buy spray "vinyl dye" from mail order sources...it may not be 'dye' at all. Buy SEM vinly dye from a local professional auto paint supplier. They can mix-to-match an existing piece or mix to original color specs easily. I refurbished my '71 and kept all pieces except the parking brake console (which was badly broken). You can't tell the other pieces from new after the redo.
To replace or restore?
