1969 Identification Help
Old May 4, 2009 | 11:50 AM
andycw's Avatar
andycw
Default 1969 Identification Help
Can anyone tell me what the holes in the center of the console are above the fuel and tempo gauge? Also, the orange wire was found under my shifter console, what is it for?
Old May 4, 2009 | 12:09 PM
Can Am 1969's Avatar
Can Am 1969
Default ID info
Andy - The holes are not stock to a '69 Corvette. I don't think the power antenna switch is either. Not a big deal - these gauge bezels are always broken at their thin points and can be replaced ($$) if you want. Or just fill the holes, shoot it with the correct semi-flat black paint, and forget it ever happened. The orange wire MIGHT be for the lighter - I don't have access (at work) to the wiring diagram, but I'm sure someone here will be able to advise you shortly.
Old May 4, 2009 | 12:23 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Can Am 1969
...The holes are not stock to a '69 Corvette. I don't think the power antenna switch is either....
The two drilled holes beneath the CORVETTE nameplate and the square hole cut beneath it are not stock. Ditto for the power entenna.
The rectangular slot with the two U-nuts is stock for non-AC cars. Fresh air riser plugs in behind the slot and has two trim screws to hold it utilizing the U-nuts. The assembly instruction manual (AIM) will show the installation and will help chase down the wire terminal you found under the console.
Old May 4, 2009 | 02:28 PM
GD70's Avatar
GD70
Here's a pic of the air duct from my 70 and the AIM diagram.
Glenn
Old May 4, 2009 | 02:38 PM
427basketcase's Avatar
427basketcase
The orange wire is for the lighter, but through the years it has been a convenient source of non switched power for other accessories.
Old May 4, 2009 | 03:17 PM
schmegeggie's Avatar
schmegeggie
Sorry to say.....it's the work of Bubba!
Old May 4, 2009 | 04:02 PM
andycw's Avatar
andycw
Default bubba
could we all go find bubba and whip his arss!!!!
Old May 4, 2009 | 04:13 PM
remanking's Avatar
remanking
That wire could be for the alarm if your car has one.
To 1969 Identification Help
