Rear Sway bar help
Old May 8, 2009 | 10:01 PM
doctorgene's Avatar
doctorgene
The sway bar needs to be on top of the bracket, no spacers at the frame. You also will find that it will be hard to start your caliper bolts with the sway bar bracket in the way. Post # 13 with the sway bar is the right way to install, # 16 is not right, Ck With Mr. Charlie on this. He is the Man on Suspension. Gene
Old May 9, 2009 | 12:36 AM
Bee Jay's Avatar
Bee Jay
I think I said "Ignore my unorthodox sway bar mount. It's to make room for 10 1/2" wheels and tires."
I was only trying to show him how to mount the bracket. You can read more about my sway bar mods in my signature. No problem with the caliper bolts.
Bee Jay
Old May 11, 2009 | 08:49 AM
greg75vette's Avatar
greg75vette
Originally Posted by TheSkunkWorks
Vette79C3, yes, the example you sight should be better balanced F/R than would the OP's combo with those same bars, but I still question the use of such a large rear bar in lieu of a firmer rear spring and/or 7/16" bar. IMCO spring choices should come first (the harder you intend to run the more important this item becomes), then however much bar(s) as necessary to augment roll resistance and tune balance.
It happens that with my 860# coils (after clipping them I'm at ~900#) I needn't rely on a huge bar as is commonly thought of as the "norm", and thus have more front grip available owing to less lateral weight transfer. Those big springs also contribute to anti-dive, as well as anti-bottoming, btw. My shark's weight distribution is subject to significant change while it's being made over, so I'll likely be testing rear spring rates again to re-balance it, for me.
As for balance, IMCO perfectly neutral steady state cornering balance isn't quite the holy grail it's exalted to be, as much depends on the car, it's intended purpose and the driver's style and ability. Just how often does one find themselves hustling around a skid pad, anyway(?) Tuning has a lot to do with managing transitions. Also, a car which seems nimble and "perfectly neutral" when pressed to 7/10ths of its potential may suddenly become diabolical at ~10/10ths, not to mention if/when you're suddenly forced to give up the throttle mid-corner.
Well said.
Old May 11, 2009 | 08:52 AM
Vette79C3's Avatar
Vette79C3
Thanks. My configuration does incorporate a larger front sway bar (1.125) and a custom rear sway bar (.75) with OEM springs and nice bilstein shocks. I have noticed that the rear end is a little looser. Curious if this configuration is the "Norm" or even if I am gaining anything over the stock setup?
Old May 11, 2009 | 05:01 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Well, you've gained additional roll stiffness, but you could have accomplished more or less the same with less bar and more spring, and have maintained better overall grip (read, "higher cornering capability"), as bigger bars carry the penalty of significantly increasing lateral weight transfer. Yes, nimble responsiveness is a good thing (to a point), but, like balance, it's only one facet of "handling". Focus too much on any one of them, and IMCO it's easy to overlook the bigger picture and end up making undesirable compromises elsewhere.
The Bilsteins are almost always a good call, but I'd urge that you leave some margin for error on the street if you're already noticing it being looser. FWIW, I wouldn't worry with what is the "norm", rather with what actually works for you.
