Need '79 step by step steering column help
http://forums.corvetteforum.com/c3-g...ly-photos.html
This one too.
http://forums.corvetteforum.com/c3-g...a-71-pics.html
http://jimshea.corvettefaq.com/?page_id=4
My papers on the 1969-82 Corvette steering columns start with just working on the "head" part of the steering column while it is still in the car. Replacing the lock cylinder and key warning buzzer.
The second paper addresses pulling the column out of the car and then replacing the ignition switch, turn signal switch, dimmer switch, and lower bearing.
The third paper addresses dimmer pivots, lock shoes, rack and sectors, and tightening support screws.
Go to www.corvettefaq.com
Click on Jim Shea's Steering Papers
Click on Corvette Steering Papers
Scroll down to the ADJUSTABLE STEERING COLUMN INFORMATION
Download Tilt & Telescoping Column 69-82 Disassembly & Repair Papers #1, #2, & #3 as required.
Also Download T&T Column 69-82 D&R Pics #1, #2, & #3 as required.
Good luck,
Don't forget that additional help is only a computer click away.
Jim
Good luck,
Jim
I rebuilt my steering column a while back using your papers and I'd like to say thank you.
