Making some progress, she's on the rack
Old May 11, 2009 | 02:49 PM
70BBvert's Avatar
70BBvert
Default Making some progress, she's on the rack
gettin' pulled back into shape. Here's a few pics from the festivities on Sat.
On the rack set up on a couple of 6 x 6's stacked up to clear the laser
With three points level frame was sitting about 1/2" up at body mount 1 on the passenger side
Took the twist out first, then pulled the left side forward to square it up.
Lots of readers for the laser
The system measures to 1 mm. It was way out to begin with, but now was level and the center section was perfectly square. They'll be working on the front section tues night. Hopefully I can swing by & take some more pics.
Jim
Old May 11, 2009 | 05:10 PM
Alan 71's Avatar
Alan 71
Hi Jim,
Interesting pictures!
SOME progress must make you feel a bit better.
Regards,
Alan
Old May 11, 2009 | 05:26 PM
70BBvert's Avatar
70BBvert
Originally Posted by Alan 71
Hi Jim,
Regards,
Alan
Sure does Alan. The mechanic doing the pull is actually the tech from the laser measuring company, Genesis. Since they don't do a lot of full frame cars anymore he's training one of the guys at the same time. also using the newest laser system and trying to get the owner to upgrade Just the laser is $8,500
Hope I'm not paying for it
Jim
Old May 11, 2009 | 09:09 PM
Road-Race Vette's Avatar
0Road-Race Vette
Former Vendor
glad to see you are on the right track
Old May 11, 2009 | 09:27 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Interesting seeing this done. I have never seen this done before quite like this. I have seen it done on tv. Cool pics, hopefully you are able to get some more.
Old May 11, 2009 | 09:43 PM
72LS1Vette's Avatar
72LS1Vette
That frame is probably going to end up straighter than when it came out of the factory.
Rick B.
Old May 12, 2009 | 09:34 AM
70BBvert's Avatar
70BBvert
Stan, Finally can't wait to get her back home and start working again Great work on Snowman's car, been watching that thread as well
Eddie
I've seen it done a bunch of times on full frame & uni body cars. Still find it fun to watch, just don't stand behind the towers in case a chain or pull bracket lets loose
Rick
Probably I don't think the factory tolerances were that close. I hear it was +/- 1/8" Wouldn't surprise me based on the adjustment slots in all the brackets & body mounts.
Jim
Old May 12, 2009 | 10:10 AM
noonie's Avatar
noonie
What published reference specs are they using?
Old May 12, 2009 | 01:49 PM
70BBvert's Avatar
70BBvert
Saturday he was using the specs from the AIM. First step was to get the frame level & take the rack out of the center section. He has an old spec book that he forgot Sat but will bring tonight that has the 72 spec's. Tried to find better specs on line but couldn't find any. Especially one's that would show the lower ball joint location.
Jim
Old May 12, 2009 | 07:25 PM
Alan 71's Avatar
Alan 71
Do ANY cars still have frames today or are they all unibody?
Just curious.
Regards,
Alan
Old May 12, 2009 | 07:39 PM
noonie's Avatar
noonie
Jim
The frame machine manufacturers used to have very detailed specs for the frame, a lot more detailed than the aim.
I would think that info would be part of the price of the fancy laser system.
Old May 12, 2009 | 10:43 PM
70BBvert's Avatar
70BBvert
I know, the key is used to. Getting them out of archives is the trick. Found some additional info on line earlier. No work tonight & I'll be traveling Thurs - Sun so I guess it'll be phone calls for the next few days.
Alan
I can't think of any "new" full frame cars at the moment. Everything is now uni body, except the Vette of course .
Jim
Old May 12, 2009 | 11:21 PM
724544SPD's Avatar
724544SPD
Alan
Jim
Actually there are still a few conventional frame vehicles still in production. Most trucks, vans, SUV's of course but also passenger cars like the Crown Victoria/Grand Marquis.
Late model Vettes are actually a high strength low alloy steel unitized conventional frame design.
Your frame pull is looking good. I have to do the same to mine when I get the body off. At one point in time someone bottomed out my Vette causing the trans crossmember to bend upward about 1/4 inch.
I guess the term "drive it like you stole it" also applied back in 1972. Or was it "if you see it, run over it"?
Old May 13, 2009 | 01:51 PM
70BBvert's Avatar
70BBvert
In my case it was " If you see it - hit it" Besides the frame damage, I already replaced three bent control arms
Jim
To Making some progress, she's on the rack
