Ralley Wheel polishing help
Old May 17, 2009 | 08:45 PM
randommj's Avatar
randommj
Default Ralley Wheel polishing help
Ive heard of a few forum members taking stuff like 2000 grit sand paper to the wheels and polishing them up, I need a good time consuming project that will keep me from spending money, can you guys help me on getting started? what do I need? and what are some tips? pictures are always welcome!
Miles
Old May 17, 2009 | 08:52 PM
81shark2008's Avatar
81shark2008
Miles
if that's your girlfriend you shouldn't need help staying occupied just messing with ya. i would google it i've heard of coca cola to lime juice, google it or ask jeeves it and you'll probably find a good proven method, good luck
Old May 17, 2009 | 09:20 PM
BigBlockTank's Avatar
BigBlockTank
What part of the wheel are you trying to polish? Mine are painted silver, the cap and trim rings are chrome.
Old May 17, 2009 | 10:53 PM
randommj's Avatar
randommj
the cap and the ring, mine look like brushed steel right now but I would like them to look like chrome
and yes that is my girlfriend, but shes in Bloivar for the summer and Im in Joplin.....
Miles
Old May 17, 2009 | 11:12 PM
BigBlockTank
Miles
Miles,
Start out with Bon-Ami bar from the grocery store. Use a wet towel to rub over the bar and then polish out the rings and caps. I've been a sheetmetal worker/painter since I came in the Air Force in 75. This Bon-Ami bar is about the best, cheapest thing I've find for chrome and glass cleaning. Try it on your mirrors too.
Then try your 2000 grit wet sandpaper. I've also used 0000 steelwool with a fair amout of success. Use some 3M Finesse-it II with the steelwool. Don't forget, on the chrome, it's straight lines, no wax on- wax off circles.
Good Luck, let us know,
BBTank
Old May 18, 2009 | 12:01 AM
Mark G's Avatar
Mark G
Check out this video:
http://www.youtube.com/watch?v=LfWY9VEmsvc
You may want/need to sand away the imperfections prior to polishing. You could get a 9" grinder at Harbor Freight pretty cheap and the right buffing pads (Eastwood) and do a great job. Wish I'd have thought of this years ago on other rims I've done. I always did it the 'hard' way. I'm going to try this on my vette rims when I'm ready to polish them up. Good luck.
Mark G
Old May 18, 2009 | 06:10 PM
randommj's Avatar
randommj
bump
Id also like to do this to my rocker panels (if I can get them off with the side pipes) there was a forum member with a yellow vette and he got his to look like chrome, if anyone knows his name it would be of great help
Miles
Old May 18, 2009 | 06:29 PM
Alan 71's Avatar
Alan 71
Hi Miles,
I believe the trim rings are stainless steel with 'flash' chrome on them. You need to be careful that you're not too aggressive or you'll buff through the chrome and get to see what a different color stainless steel is compared to chrome.
The center cap 'hat' is chromed pot metal and the saucer is stainless steel like the rings. Be careful you don't buff the black paint off the 'hat' because its pretty difficult to duplicate.
The rocker trim is anodized aluminium. Once you buff through the anodizing you'll be on your own.
Have Fun!
Regards,
Alan
Old May 18, 2009 | 07:01 PM
randommj's Avatar
randommj
I think that the chrome has already been removed somehow from mine, here's how they look, sorry I dont have a better picture of them
and here are my dads in the same light
Miles
Old May 18, 2009 | 07:09 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I would use some Never Dull or some Dupont #7 and then follow it up with a good polish/sealant like Zaino All in one.
Old May 18, 2009 | 07:23 PM
randommj's Avatar
randommj
I also have a spot of rust on my drivers side front ring, its only about half the side of a dime, this is why Im leaning tward a sanding instead of a buff, last year I took mother mag and aluminum to them and it helped alot but its still not as shiney as it should be
Miles
Old May 18, 2009 | 07:44 PM
Muddywaters's Avatar
Muddywaters
Miles...I've buffed and poloshed basically all my stainless and aluminum, ect... using the info from this site...http://www.caswellplating.com/buffs/buffman.htm
Some of my stainless, I had to start with a hammer and dolly. From there, files, and then sandpaper... 100, up to 1500, 2000. Then it was finally taken to the buffer... Muddy
Old May 18, 2009 | 08:03 PM
noonie's Avatar
noonie
I wouldn't touch it with any sandpaper etc. before you try polishing it first, properly.
SS contains chromium, the more % the more it will shine. It's the chromium content you are really polishing for the bright shine.
SS is very hard and you need a super hard very fine abrasive to polish it to it's highest finish along with power tools.
The buffing pads are called "mops"
"Calcined alumina" is usually what the pros use for polishing ss.
It's a lot of work.
Old May 19, 2009 | 11:20 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
The rings on the white car do not look like original 4-clip trim rings from the pic. I can't make out the edge around the outside and they look a bit more rounded. If they are not original style, its hard to say what is there. They may or may not be chrome over stainless or just stainless. There should be no rust if they are stainless. Either way I prefer a cotton wheel with white polishing rogue. If you polish thru the chrome, Alan is right, you wil see the difference in the color.
Old May 19, 2009 | 11:43 PM
BigBlockTank
FWIW, what I told you will work.
Old May 20, 2009 | 05:40 AM
saudivette's Avatar
saudivette
Mine were as rough as a badger's ****! I started out with 240 wet and dry to remove deep scratches etc, then moved up grades until I was using 800. Then I hit them with some Mother's aluminium polish and my buffer. I clear powder coated the chrome spinner...
Old May 20, 2009 | 09:40 AM
bobbarry's Avatar
bobbarry
I was going to say they look like the trim-rings from a 4wd K5 Blazer (I slapped some of those onto some 7" Rally wheels on another car). Those will not shine up without an inordinate amount of polishing. If you're going for the factory-fresh look, you'd be better-off starting with the correct Vette trim-rings.
To Ralley Wheel polishing help
Old May 20, 2009 | 11:17 PM
Paul Drennan's Avatar
Paul Drennan
The rings on the white car are indeed truck rings and they have a somewhat "brushed" finish that I don't think will ever polish into a chrome looking finish. Since you don't have original rings, why not just invest in a set of chrome plated rings from one of the venders? I have been using them for years because I like the look over polished stainless. You can probably buy a whole set for what 1 decent original ring would cost. I love a project as much as the next guy, but I would put the effort towards another area.
Old May 21, 2009 | 12:42 AM
Skip Burney's Avatar
Skip Burney
I cleaned mine up with a scotch brite pad the then polished them with a buffer and some chrome cake compound
Old May 22, 2009 | 02:29 PM
randommj's Avatar
randommj
I never noticed it before, but mine dont have then little lip on the outer ring that my dads have, so it looks like I get to go to the junk yards now!
Thanks for your help, Ill probably have to buff and sand the ones I find, so Ill be back! haha
Miles
