Differencial fluid
Old May 20, 2009 | 10:07 PM
78VetteChic's Avatar
78VetteChic
Default Differencial fluid
How often have ya'll been changing the differential fluid?
Old May 20, 2009 | 11:04 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
I always check the fluid level with each oil change, but I don't change the fluid. Unless you're racing the car there shouldn't be anything to contaminate the fluid except what ever might wear from the clutch packs.
Old May 20, 2009 | 11:19 PM
7T1vette's Avatar
7T1vette
It should last at least 50,000 miles or 5 years [whichever comes first]. If you are a fanatic about changing oil frequently, make it 25,000 or 3 years. [It doesn't have a drain plug, does it?]
Old May 20, 2009 | 11:38 PM
78VetteChic
No drain plug in a 78 so it'll have to be siphoned. Apparently I'm overdue since it's been more than 5 years. I'm not having any problems with it - just thought I should ask.
Thanks!
Old May 21, 2009 | 12:46 AM
TWA747/79's Avatar
TWA747/79
I changed mine when I started getting a little growl from the area of the differential. It seemed to get more pronounced when turning in reverse or turning very slowly in forward. We used an additive (can't remember the name) and this solved the problem. This problem happened about 10 years and 12,000 miles ago and has not returned.
We enjoyed meeting you at the Shark C3 show. I have the brown 79.
Old May 21, 2009 | 05:52 AM
RunningMan373's Avatar
RunningMan373
GM Axle Lubricant, Dino, SAE 80W-90, p/n 89021671 and 2 bottles of GM friction modifier.
Old May 21, 2009 | 08:03 AM
pws69's Avatar
pws69
1 bottle GM Posi Additive + Mobil 1 Gear - been perfect for years!
Old May 21, 2009 | 10:51 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Agree, use the recommended conventional lube and the 4 oz. bottle of GM friction modifier. Eaton "stongly recommends" against the use of synthetic gear oil for our posi's.
Old May 21, 2009 | 11:48 AM
pws69's Avatar
pws69
Yea, right - it's "too slippery"
Old May 21, 2009 | 12:20 PM
moss4wvu's Avatar
moss4wvu
i am about to change mine. The pinion seal leaked so i replaced it and figured what the heck since most had leaked out anyways
Old May 21, 2009 | 02:12 PM
78VetteChic
TWA747/79 - It was great talking with you and your wife too!
I looked up rear axle lub change in the GM Service Manual and it says "normally doesn't require to be changed for the life of the vehicle" - except if "pulling a trailer, change ever 15,000." I wonder how GM defines how long the vehicle is suppose to last.
Old May 24, 2009 | 03:35 PM
RIJVETTES's Avatar
RIJVETTES
I just had the Dana 44 rebuilt in my 80- deeper gears, new seals and rebuilt posi. The shop, ProGear, in San Diego, does nothing but rearends, and did a great job. Its good to feel better acceleration, and no more oil being slung around the rear exhaust pipes and on the garage floor. They recommend changing the oil every 50K miles. Thats when I did mine last- and it was pretty black and gritty before the rebuild. I'll watch it a little more frequently and change it earlier if needed. They also strongly recommend against using synthetic oil, and do recommend using the heavier dino rear gear oil- 90 140 , with the posi additive.
To Differencial fluid
