Undercoating
Old May 22, 2009 | 09:04 AM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Default Undercoating
What works best for removing dealer-installed undercoating from 1969? The heaviest appears to be in the wheel wells. I'm trying to avoid bad fumes in the house as well as blowing myself up and/or burning the house down. I used an aircraft stripper on the spare tire carrier, which worked quite well, but that was outside in a tub. I've been told to use lacquer thinner as a final cleaner/prep on much of the underbody.
Old May 22, 2009 | 10:40 AM
7T1vette's Avatar
7T1vette
Depending on how thick it is, you might be wise to start by getting most of it off with a putty knife. Lacquer thinner will 'cut' it, but it will take a lot just to get the remaining stuff off after you use the putty knife. Also, you may want to leave some of it at the upper portion of the wheelwells just to prevent any rocks thrown by your tires from hitting there and causing 'star' cracking in your paint [on top of the fenders]. When done with the undercoating, use semi-flat black spray paint to dress up the wheelwell areas.
Old May 22, 2009 | 10:54 AM
schmegeggie's Avatar
schmegeggie
Step 1) Buy a 12 pack of beer
Step 2) Grab a putty knife
Step3) Open first beer
Step 4) Scrape until first beer is finished
Step 5) Repeat steps 3 & 4
Old May 22, 2009 | 11:18 AM
Faster Rat's Avatar
Faster Rat
I'll need a lot of beer to get thru this phase of the project. Good thing I have that 2nd refrigerator in the garage...the little lady won't count my trips into the kitchen for another, complaining that I'm bringing dirt into the house. If she doesn't see me, she's happy.
Old May 22, 2009 | 12:26 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I really recommend wearing gloves, these coatings will break off in a very sharp small pieces and will get under your finger nails causing tons of pain! (ask me how I know!).
Old May 22, 2009 | 06:17 PM
rdrunnur's Avatar
rdrunnur
Check out Eastwood
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
Rd
Old May 22, 2009 | 07:01 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
I've done this on six cars now and it's my least favorite chore of a restoration. Nasty business.
The undercoating is an oil based product so I've used engine degreaser (the regular liquid, not foaming), called Castite from O'Reilly's (Gunk isn't as effective) which comes in 20 oz. spray cans. Or I've used WD-40, $14 by the gallon at Lowe's plus a $2 sprayer.
The Castite is superior to the WD. You'll need 6-8 cans to complete all four wheel wells and the underbody.
The Castite really softens up the undercoating.
Also, you'll need a 1" metal paint scraper (forget plastic) and 4-6 sheets (10" x 12"?) of the course Scotch-Brite. Cut each sheet into fourths.
Also, purchase 20 or so small terry cloth towels. Lowes used to have the bag of rags for about $15.
And yeah, as recommended above, a couple of dozen vinyl gloves are a good idea.
Pretty straight forward.
Spread a big plastic sheet or a lot of newspapers under your work. Do about a 10" x 10" square at time;
1) spray
2) scrape
3) spray again
4) rub with Scotch-Brite
5) spray again
5) wipe clean with your rag
6) Repeat as necessary
Good luck!
Old May 22, 2009 | 10:04 PM
Faster Rat's Avatar
Faster Rat
Thanks for the suggestions. Nothing like hearing from those who have been there and done that. I sure am glad I've followed others advice so far, like:
1. Educate yourself and look before you buy. Joined NCRS and searched for 1-1/2 years.
2. Drive the car and enjoy it before spending more money. See if you like the hobby.
3. Restore the mechanicals and underbody first. They are the most important & difficult.
4. Save the paint, chrome, carpet and interior for last.
Old May 22, 2009 | 10:21 PM
3JsVette's Avatar
3JsVette
One additional step that has not been mentioned is it doesn't hurt to have a heat gun. It really helps on the tough spots but be carefull and keep the gun moving because they get VERY hot. Of course you can't use it on top of anything flamable. Work in a small area and putty knife will scrape the undercoat off. Afterwards you can go over the area with a solvent.
To Undercoating
