Radio Wiring '77 C3
Anyone have a diagram of factory wiring for radio plugs on a 77 Corvette? This one like so many others has had the factory plugs cut and aftermarket radio was installed. Wiring cut and can't make heads or tails of it. Speaker harness no problem but the other two plugs I can't seem to figure out. Probably going to go from sources and run forward but I need see a diagram or sketch. I am assuming that there are three plugs like most other GM's? Thanks for any help someone will give!
http://www.europeancorvette.com/html...l_diagrams.htm
